Salta al contenuto principale
Samsung Gear VR Trackpad Replacement
Cosa ti serve
    1. Samsung Gear VR Trackpad Replacement, Front Phone Mount: passo 1, immagine 1 di 3 Samsung Gear VR Trackpad Replacement, Front Phone Mount: passo 1, immagine 2 di 3 Samsung Gear VR Trackpad Replacement, Front Phone Mount: passo 1, immagine 3 di 3
      • Remove the front cover to access a plate that holds the phone in place during use.
      • Remove the four corner screw covers with a metal spudger to reveal four screws.
      • Remove the sticker located at the top center to reveal two additional screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Gear VR Trackpad Replacement: passo 2, immagine 1 di 2 Samsung Gear VR Trackpad Replacement: passo 2, immagine 2 di 2
      • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
      • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
      • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Gear VR Trackpad Replacement, Motherboard: passo 3, immagine 1 di 1
      • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
      • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Gear VR Trackpad Replacement: passo 4, immagine 1 di 1
      • You can now remove the motherboard from the mask.
      • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Gear VR Trackpad Replacement, Inner Mask: passo 5, immagine 1 di 3 Samsung Gear VR Trackpad Replacement, Inner Mask: passo 5, immagine 2 di 3 Samsung Gear VR Trackpad Replacement, Inner Mask: passo 5, immagine 3 di 3
      • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
      • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Gear VR Trackpad Replacement, Trackpad: passo 6, immagine 1 di 2 Samsung Gear VR Trackpad Replacement, Trackpad: passo 6, immagine 2 di 2
      • Pry the trackpad sensor loose from the mask.
      • I found that prying the metal spudger underneath the small outcropping at the bottom of the sensor to be the easiest way to remove the piece.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Membri
21 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 30
Tutti i Tempi: 1,461
