Salta al contenuto principale
Samsung Gear VR Lens Replacement
Cosa ti serve
    1. Samsung Gear VR Lens Replacement, Front Phone Mount: passo 1, immagine 1 di 3 Samsung Gear VR Lens Replacement, Front Phone Mount: passo 1, immagine 2 di 3 Samsung Gear VR Lens Replacement, Front Phone Mount: passo 1, immagine 3 di 3
      • Remove the front cover to access a plate that holds the phone in place during use.
      • Remove the four corner screw covers with a metal spudger to reveal four screws.
      • Remove the sticker located at the top center to reveal two additional screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Gear VR Lens Replacement: passo 2, immagine 1 di 2 Samsung Gear VR Lens Replacement: passo 2, immagine 2 di 2
      • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
      • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
      • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Gear VR Lens Replacement, Motherboard: passo 3, immagine 1 di 1
      • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
      • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Gear VR Lens Replacement: passo 4, immagine 1 di 1
      • You can now remove the motherboard from the mask.
      • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Gear VR Lens Replacement, Inner Mask: passo 5, immagine 1 di 3 Samsung Gear VR Lens Replacement, Inner Mask: passo 5, immagine 2 di 3 Samsung Gear VR Lens Replacement, Inner Mask: passo 5, immagine 3 di 3
      • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
      • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Gear VR Lens Replacement, Lens: passo 6, immagine 1 di 2 Samsung Gear VR Lens Replacement, Lens: passo 6, immagine 2 di 2
      • Using the metal spudger, push in the 3 tabs around the lens housing to release the lens. Repeat for both lens for a total of 6 tabs.
      • Do not push in too hard or you might brake the tabs.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Gear VR Lens Replacement: passo 7, immagine 1 di 1
      • Flip the headgear and use your fingers to gently remove lens from mask. Repeat for both lens.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team S4-G6, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Membri
14 guide realizzate
1Commento della guida
There are multiple mistakes in this tutorial, which made it hard to follow the steps:
- in step 2.1, you are missing 4 screws below each side of the latching mechanism.
- in step 5, the mask does not come apart after unscrewing the 8 screws. I am currently stuck at this step as I am writing this. Wish me luck.
L.H. - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 42
Tutti i Tempi: 6,850
