Salta al contenuto principale
Samsung Gear Fit Screen Replacement
Cosa ti serve
    1. Samsung Gear Fit Screen Replacement, Watch Band: passo 1, immagine 1 di 2 Samsung Gear Fit Screen Replacement, Watch Band: passo 1, immagine 2 di 2
      • Place your thumbs on the ends of the screen.
      • Push the watch outward while pulling the band away from the watch.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Gear Fit Screen Replacement, Screen: passo 2, immagine 1 di 1
      • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
      • For step-by-step instructions on using an iOpener, see the Istruzioni iOpener.
      • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Gear Fit Screen Replacement: passo 3, immagine 1 di 3 Samsung Gear Fit Screen Replacement: passo 3, immagine 2 di 3 Samsung Gear Fit Screen Replacement: passo 3, immagine 3 di 3
      • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
      • Gently pry the screen loose using a plastic opening tool.
      • If the screen doesn't easily come loose, more heating may be required
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung Gear Fit Screen Replacement: passo 4, immagine 1 di 3 Samsung Gear Fit Screen Replacement: passo 4, immagine 2 di 3 Samsung Gear Fit Screen Replacement: passo 4, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • Using tweezers as a lever, pry the inner assembly out of the external casing.
      • This will be harder than removing the screen. Moderate force may be required.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung Gear Fit Screen Replacement: passo 5, immagine 1 di 3 Samsung Gear Fit Screen Replacement: passo 5, immagine 2 di 3 Samsung Gear Fit Screen Replacement: passo 5, immagine 3 di 3
      • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung Gear Fit Screen Replacement: passo 6, immagine 1 di 2 Samsung Gear Fit Screen Replacement: passo 6, immagine 2 di 2
      • Gently peel the screen assembly up and away from the device using tweezers.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 17 persone hanno completato questa guida.
Nathan Powell
Membro da: 04/24/14
1.584 Reputazione
3 guide realizzate
Cal Poly, Team 11-49, Amido Spring 2014 Membro di Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 Membri
4 guide realizzate
28Commenti sulla guida
Hi!
Thank you very much for this tuto. But wher can we acquire the screen ???
Thanks a lot.
AB
aaa - Rispondi Condividi
Where can you buy replacement screen?
Yele Olaniyi - Rispondi Condividi
I'm also finding it difficult to buy a replacement screen too. Has anyone discovered some. I thought this website was selling some not too long ago. Any more coming in?
Rochelle - Rispondi Condividi
Hi guys,
is it possible to detach the display unit from the protective plastic cover (I think it's not glass) ?
alexxtodorov - Rispondi Condividi
Does anyone know where to get the replacement screen?
MrGratts - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 34
Tutti i Tempi: 54,677
