Salta al contenuto principale
Samsung Galaxy Watch Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy Watch Motherboard Replacement, Opening Procedure: passo 1, immagine 1 di 1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Samsung Galaxy Watch Motherboard Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Watch Motherboard Replacement: passo 2, immagine 2 di 2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Samsung Galaxy Watch Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Galaxy Watch Motherboard Replacement: passo 3, immagine 2 di 2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Samsung Galaxy Watch Motherboard Replacement: passo 4, immagine 1 di 2 Samsung Galaxy Watch Motherboard Replacement: passo 4, immagine 2 di 2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch Motherboard Replacement: passo 5, immagine 1 di 3 Samsung Galaxy Watch Motherboard Replacement: passo 5, immagine 2 di 3 Samsung Galaxy Watch Motherboard Replacement: passo 5, immagine 3 di 3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Samsung Galaxy Watch Motherboard Replacement, Core Assembly Removal: passo 6, immagine 1 di 2 Samsung Galaxy Watch Motherboard Replacement, Core Assembly Removal: passo 6, immagine 2 di 2
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Samsung Galaxy Watch Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Galaxy Watch Motherboard Replacement: passo 7, immagine 2 di 2
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  8. Samsung Galaxy Watch Motherboard Replacement, Motherboard: passo 8, immagine 1 di 2 Samsung Galaxy Watch Motherboard Replacement, Motherboard: passo 8, immagine 2 di 2
    • Use a spudger to disconnect the hall sensor flex cable.
  9. Samsung Galaxy Watch Motherboard Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Watch Motherboard Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Watch Motherboard Replacement: passo 9, immagine 3 di 3
    • Use a pair of tweezers to gently peel both button cables from the plastic frame.
    • The button cables have metal plates behind them. These plates should remain on the cables.
  10. Samsung Galaxy Watch Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove the single Phillips #00 screw (3.4 mm length).
  11. Samsung Galaxy Watch Motherboard Replacement: passo 11, immagine 1 di 3 Samsung Galaxy Watch Motherboard Replacement: passo 11, immagine 2 di 3 Samsung Galaxy Watch Motherboard Replacement: passo 11, immagine 3 di 3
    • Insert a spudger into the small gap underneath the motherboard where the cutout in the plastic frame is.
    • Lift the motherboard by twisting the spudger.
    • Slide the motherboard out from under the plastic tab.
  12. Samsung Galaxy Watch Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the motherboard.
Conclusione
If possible, turn on your device and test your repair before resealing.
Altre 7 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 03/31/14
117.720 Reputazione
188 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.539 Guide realizzate
7 Commenti
Anyone know where to purchase a Galaxy Watch mother board?
lorne serpa - Replica
What is the part number, or where can you get the motherboard?
Nick Henthorn - Replica
Where can the motherboard be purchased from for Galaxy Watch ?
Mohammed Aamir - Replica
I got a motherboard on ebay. Including import duties it was something like 90$. Shipped to Denmark.
Definitely cheaper than repair shop and absolutely more fun! :)
Agris Jurjans - Replica
Hello,
Do you know if switching a motherboard from a GW46 Bluetooth only (R800) to a GW46 LTE (R805) is a straight swap or additional parts are needed?
As my R800 sensors are dead and i need to replace the motherboard and the back cover anyway.
Thanks
BRazvy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 153
Tutti i Tempi: 11,849
