Salta al contenuto principale
Samsung Galaxy View Battery Replacement
Cosa ti serve
    1. Samsung Galaxy View Battery Replacement, Kickstand: passo 1, immagine 1 di 1
      • Place the device on a hard flat surface with its screen facing downwards.
      • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Galaxy View Battery Replacement: passo 2, immagine 1 di 3 Samsung Galaxy View Battery Replacement: passo 2, immagine 2 di 3 Samsung Galaxy View Battery Replacement: passo 2, immagine 3 di 3
      • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
      • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
      • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
      • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    1. Samsung Galaxy View Battery Replacement, Battery: passo 3, immagine 1 di 2 Samsung Galaxy View Battery Replacement, Battery: passo 3, immagine 2 di 2
      • Check the device is completely turned off.
      • Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
      Chiedi a FixBot
      Aggiungi Commento
    2. Samsung Galaxy View Battery Replacement: passo 4, immagine 1 di 3 Samsung Galaxy View Battery Replacement: passo 4, immagine 2 di 3 Samsung Galaxy View Battery Replacement: passo 4, immagine 3 di 3
      • Remove the 4 screws (4 mm in length) using the Phillips #0 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Samsung Galaxy View Battery Replacement: passo 5, immagine 1 di 3 Samsung Galaxy View Battery Replacement: passo 5, immagine 2 di 3 Samsung Galaxy View Battery Replacement: passo 5, immagine 3 di 3
      • Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
      • Insert the metal spudger within the opening.
      • Move the metal spudger down the seam, prying the back panel open as you go.
      • Once a large enough opening is made, pry the entire back panel off with your hand.
      • You will hear loud popping from the magnetized latches. This is not causing damage to the device and will require some force to open.
      Chiedi a FixBot
      Aggiungi Commento
    4. Samsung Galaxy View Battery Replacement: passo 6, immagine 1 di 2 Samsung Galaxy View Battery Replacement: passo 6, immagine 2 di 2
      • Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. Samsung Galaxy View Battery Replacement: passo 7, immagine 1 di 3 Samsung Galaxy View Battery Replacement: passo 7, immagine 2 di 3 Samsung Galaxy View Battery Replacement: passo 7, immagine 3 di 3
      • Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
      • Remove the battery from the device.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 40 persone hanno completato questa guida.
Roger Pena
Membro da: 10/06/16
1.141 Reputazione
Una guida realizzata
Cal Poly, Team 4-5, Livingston Fall 2016 Membro di Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Membri
12 guide realizzate
29Commenti sulla guida
I’m not sure if it’s the battery or the cord
Swheet - Rispondi Condividi
What size is the battery that fits into the SAMSUNG TAB VIEW?
Ricky Lee Lidel - Rispondi Condividi
Thank You, Sooo much. This guide is a true money and time saver. Worked like a gem .
Mike Rowe - Rispondi Condividi
I can't find Lithium ION 11.3 V 5700mAh battery for my Samsung Galaxy 18.4View Tablet, does anyone know where to get one?
What's difference between a 5700mAh battery and 5900mAh battery
Sue ELLEN R FONTENOT - Rispondi Condividi
Where can I find battery replacement for galaxy view
Greg Dover - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 14
Ultimi 30 giorni: 75
Tutti i Tempi: 27,865
