Salta al contenuto principale
Samsung Galaxy Star Pro Screen Replacement
Cosa ti serve
  1. Samsung Galaxy Star Pro  Screen Replacement, Battery Replacement: passo 1, immagine 1 di 1
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Galaxy Star Pro  Screen Replacement: passo 2, immagine 1 di 2 Samsung Galaxy Star Pro  Screen Replacement: passo 2, immagine 2 di 2
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Galaxy Star Pro  Screen Replacement, Screen: passo 3, immagine 1 di 1
    • After following how to remove the battery, unscrew the five 1.2mm Phillips Screws on the one back of the phone using screw driver. Use the J00 Phillips head screw bit to take out the screws
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Galaxy Star Pro  Screen Replacement: passo 4, immagine 1 di 1
    • Once screws are removed turn the phone over and use the plastic opening tool and unclip the connector holding the screen to the motherboard.
    • Be careful to not damage the press-fit connector that connects the screen to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Galaxy Star Pro  Screen Replacement: passo 5, immagine 1 di 1
    • Us the plastic opening tool to pry apart the screen from the plastic. Start from one side and work your way around the whole phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 27
Tutti i Tempi: 2,115
