Introduzione
Wenn du die hintere Glasabdeckung von deinem Galaxy S6 entfernst, wird der Kleber, der sie festhält, zerstört. Befolge diese Anleitung, um das Klebeband auf der Glasrückseite deines Galaxy S6 zu ersetzen. Die meisten Klebestreifen werden wie abgebildet verpackt geliefert, obwohl die Folienabmessungen und die Farbe variieren können.
Bevor du anfängst, empfehlen wir dir, alle restlichen Kleber von der Glasplatte mit einem fusselfreien Tuch und Lösungsmittel wie Isopropylalkohol (mind. 90%) zu entfernen.
Bevor du dein Gerät wieder neu versiegelst bzw. mit neuem Kleber versiehst und schließt, gehe sicher dass dein Gerät wieder funktioniert indem du es einschaltest und testest.
Cosa ti serve
Ziehe die durchsichtige Folie von dem Klebestreifen ab.
Altre 141 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
9 Commenti
It would be handy to tell us a reliable place to obtain the adhesive from as iFixit doesn't appear to stock it
I snagged a replacement front and back glass adhesive and a new daughter board for the S6 from http://www.mobiledefenders.com/. They seem okay so far. Only about a buck for the adhesives, plus shipping.
Will the adhesive for a galaxy s6 work on the back cover of an s6 edge?
It won't work. Size is different. One for S6 is larger
Jimmy -
Couldn't you just cut it to size? If it's just a pad of adhesive, you should be able to just cut it to the smaller backing size. I'd assume it's non conductive, but make sure it's not blocking anything important.
Ampera -
amazon has the S6 film
While cleaning off the old adhesive the rear housing broke into 3 pieces??!! I was using a kitchen table place mat….I would have appreciated the author giving me a heads up on how fragile the rear cover is.
It’s glass. That should be warning enough.
