Salta al contenuto principale
Samsung Galaxy A3 Display / LCD Replacement
Cosa ti serve
  1. Samsung Galaxy A3 Display / LCD Replacement, Display / LCD: passo 1, immagine 1 di 1
    • Heat up the edges of the display with a heat gun or iPad opener.
  2. Samsung Galaxy A3 Display / LCD Replacement: passo 2, immagine 1 di 2 Samsung Galaxy A3 Display / LCD Replacement: passo 2, immagine 2 di 2
    • Using a pick or slim plastic tool, work around the edge of the frame to loosen the glass.
    • Watch out for the ear speaker, camera and light sensor on the top of the phone.
    • When working the glass free around the bottom of the phone, slide the tool out to avoid damaging the left and right home buttons (as shown in picture 2).
    • NOTE: The LCD is also glued to the frame and will most likely break when removing the display.
  3. Samsung Galaxy A3 Display / LCD Replacement: passo 3, immagine 1 di 2 Samsung Galaxy A3 Display / LCD Replacement: passo 3, immagine 2 di 2
    • Once the display has been disconnected, lift the top of the display away from the phone to expose the home buttons (Shown in green)
    • Pry the contacts gently off the underside of the glass and push them back into the recesses on the phone (shown in yellow).
  4. Samsung Galaxy A3 Display / LCD Replacement: passo 4, immagine 1 di 1
    • Connect the new display and seat it in the phone, without removing the plastic for the adhesive.
    • Turn the phone on to make sure the display and home buttons work. If you glue the display without testing it first, it's a pain to take it off again once it has been glued and runs the risk of the display breaking.
    • If the display works, remove the plastic covering the adhesive and seat the display in the phone. Push gently around the edges to ensure a good seal
Conclusione
To reassemble your device, follow these instructions in reverse order. Do not attempt this while driving or lovemaking :)
Altre 44 persone hanno completato questa guida.
Harvey
Membro da: 02/15/16
6.189 Reputazione
10 Guide realizzate
6Commenti sulla guida
The lcd on my phone was physically glued to the inside of the phone so it broke when trying to remove it (which wasn't a problem as it was dead anyway) but this needs to be mentioned as it isn't!
Clems - Replica
It’s been mentioned in step 2
Siamak -
nice man really cool staff
Shelton Chiuswa - Replica
Is the concept the same with newer models of the Samsung Galaxy A3?
Frederik Novak Jansen - Replica
The 2016 Model is different, so I would look for the model specific repair information:
Samsung A3 2016 Model - A310F Display / LCD Replacement
This is a guide I wrote for the 2016 model...Hope it helps!
Harvey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 72
Tutti i Tempi: 47,378
