Salta al contenuto principale
Samsung Epix Keyboard Replacement
Cosa ti serve
  1. Samsung Epix Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Just below the phone's camera, press the button and hold it
    • While the button is held down, slide the back panel off to remove it completely.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Epix Keyboard Replacement: passo 2, immagine 1 di 1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
    • Gently lift the battery and remove it from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Epix Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Using a plastic prying tool, remove the screw cover in the top left corner of the phone by lifting it up.
    • Be gentle
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Epix Keyboard Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • Three of the screws are evenly spaced on the left and right side on the back of the phone.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Epix Keyboard Replacement: passo 5, immagine 1 di 2 Samsung Epix Keyboard Replacement: passo 5, immagine 2 di 2
    • Insert the prying tool into the seam on the side of the phone and turn it slightly. Do this for each of the eight clips to unhook them
    • There are three clips on each side and two at the bottom of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Epix Keyboard Replacement: passo 6, immagine 1 di 1
    • Once all eight of the clips have been unhooked, lift the back panel gently off of the phone.
    • Be careful and do not attempt to remove the front panel. It is still connected to the phone's chassis by a ribbon cable which is located in the bottom right side of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Epix Keyboard Replacement: passo 7, immagine 1 di 1
    • Using the plastic prying tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully disconnect the ribbon cable.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Epix Keyboard Replacement: passo 8, immagine 1 di 1
    • Gently lift and remove the front faceplate
    • Exercise caution
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Epix Keyboard Replacement: passo 9, immagine 1 di 1
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove it.
    • Lift it and gently take it out the frame to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Chris
Membro da: 04/20/11
32 Reputazione
Una guida realizzata
Cal Poly, Team 15-15, Regan Spring 2011 Membro di Cal Poly, Team 15-15, Regan Spring 2011
CPSU-REGAN-S11S15G15
5 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 30
Tutti i Tempi: 2,044
