Salta al contenuto principale
Samsung Epic 4G Power Button Replacement
Cosa ti serve
  1. Samsung Epic 4G Power Button Replacement, Phone Case: passo 1, immagine 1 di 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Epic 4G Power Button Replacement: passo 2, immagine 1 di 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Epic 4G Power Button Replacement, Battery: passo 3, immagine 1 di 1
    • Remove the battery from the device by pulling the battery edge upwards.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: passo 4, immagine 1 di 1
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: passo 5, immagine 1 di 2 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: passo 5, immagine 2 di 2
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: passo 6, immagine 1 di 2 Samsung Epic 4G Power Button Replacement, Removing the Power Button: passo 6, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 24-25, Regan Fall 2012 Membro di Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 37
Tutti i Tempi: 2,753
