Salta al contenuto principale
Samsung Blackjack Screen Replacement
Cosa ti serve
  1. Samsung Blackjack Screen Replacement, Battery Cover: passo 1, immagine 1 di 3 Samsung Blackjack Screen Replacement, Battery Cover: passo 1, immagine 2 di 3 Samsung Blackjack Screen Replacement, Battery Cover: passo 1, immagine 3 di 3
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung Blackjack Screen Replacement, Battery: passo 2, immagine 1 di 2 Samsung Blackjack Screen Replacement, Battery: passo 2, immagine 2 di 2
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Samsung Blackjack Screen Replacement, SIM Card: passo 3, immagine 1 di 3 Samsung Blackjack Screen Replacement, SIM Card: passo 3, immagine 2 di 3 Samsung Blackjack Screen Replacement, SIM Card: passo 3, immagine 3 di 3
    • Place your thumb on the SIM card.
    • Slide the card out of the slot.
    Chiedi a FixBot
    Aggiungi Commento
  4. Samsung Blackjack Screen Replacement, Back Phone Casing: passo 4, immagine 1 di 2 Samsung Blackjack Screen Replacement, Back Phone Casing: passo 4, immagine 2 di 2
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
    Chiedi a FixBot
    Aggiungi Commento
  5. Samsung Blackjack Screen Replacement: passo 5, immagine 1 di 3 Samsung Blackjack Screen Replacement: passo 5, immagine 2 di 3 Samsung Blackjack Screen Replacement: passo 5, immagine 3 di 3
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
    Chiedi a FixBot
    Aggiungi Commento
  6. Samsung Blackjack Screen Replacement, Volume/Scroll Wheel: passo 6, immagine 1 di 2 Samsung Blackjack Screen Replacement, Volume/Scroll Wheel: passo 6, immagine 2 di 2
    • Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
    • Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
    Chiedi a FixBot
    Aggiungi Commento
  7. Samsung Blackjack Screen Replacement: passo 7, immagine 1 di 2 Samsung Blackjack Screen Replacement: passo 7, immagine 2 di 2
    • Use the spudger to unsnap the gold wire connection that connects the back casing to the logic board.
    • Use the spudger to unsnap the gold wire connection that connects the scroll wheel assembly to the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  8. Samsung Blackjack Screen Replacement, Motherboard: passo 8, immagine 1 di 2 Samsung Blackjack Screen Replacement, Motherboard: passo 8, immagine 2 di 2
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
    Chiedi a FixBot
    Aggiungi Commento
  9. Samsung Blackjack Screen Replacement: passo 9, immagine 1 di 2 Samsung Blackjack Screen Replacement: passo 9, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
    Chiedi a FixBot
    Aggiungi Commento
  10. Samsung Blackjack Screen Replacement: passo 10, immagine 1 di 2 Samsung Blackjack Screen Replacement: passo 10, immagine 2 di 2
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
    Chiedi a FixBot
    Aggiungi Commento
  11. Samsung Blackjack Screen Replacement, Screen: passo 11, immagine 1 di 3 Samsung Blackjack Screen Replacement, Screen: passo 11, immagine 2 di 3 Samsung Blackjack Screen Replacement, Screen: passo 11, immagine 3 di 3
    • Use the spudger to break the glue that bonds the screen to the logic board.
    • Remove the screen from the logic board. The screen will still be connected by a gold ribbon connection.
    • While gently lifting upwards on the green part of the logic board, slide the gold ribbon connected that is to the screen through the space in the side of the logic board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Everett
Membro da: 10/22/12
19 Reputazione
2 guide realizzate
Clemson, Team 14-4, Benson Fall 2012 Membro di Clemson, Team 14-4, Benson Fall 2012
CLEM-BENSON-F12S14G4
3 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 57
Tutti i Tempi: 880
