Salta al contenuto principale
Samsung 351U Keyboard Key Replacement
Cosa ti serve
  1. Samsung 351U Keyboard Key Replacement, Keyboard Key: passo 1, immagine 1 di 1
    • Select the key you would like to remove then slide the plastic opening tool beneath it until you hear a pop.
    Chiedi a FixBot
    Aggiungi Commento
  2. Samsung 351U Keyboard Key Replacement: passo 2, immagine 1 di 1
    • The key is now out and ready to be removed/replaced.
    • Be sure to only remove one key at a time so they will be in the same place as they were.
    • Clean the key and replace it into the same spot until another pop is heard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team 12-4, Eyestone Spring 2017 Membro di USF Tampa, Team 12-4, Eyestone Spring 2017
USFT-EYESTONE-S17S12G4
4 Membri
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 27
Tutti i Tempi: 1,112
