Salta al contenuto principale
Saeco Royal brewing unit disassembly
Cosa ti serve
  1. Saeco Royal brewing unit disassembly, Cream valve and spout: passo 1, immagine 1 di 3 Saeco Royal brewing unit disassembly, Cream valve and spout: passo 1, immagine 2 di 3 Saeco Royal brewing unit disassembly, Cream valve and spout: passo 1, immagine 3 di 3
    • These parts differ in details depending on the model
    • Two screws hold the part, loosen. A seal becomes free, pick up well, better still replace later.
    • Inside is a feather and a small glass ball. Store carefully.
  2. Saeco Royal brewing unit disassembly, The brewing sieve: passo 2, immagine 1 di 2 Saeco Royal brewing unit disassembly, The brewing sieve: passo 2, immagine 2 di 2
    • With a 6mm Allen key (or the key that comes with the machine), the brewing sieve can be unscrewed. It strongly determines the aroma, if it is dirty the coffee tastes bad.
  3. Saeco Royal brewing unit disassembly, The upper piston: passo 3, immagine 1 di 3 Saeco Royal brewing unit disassembly, The upper piston: passo 3, immagine 2 di 3 Saeco Royal brewing unit disassembly, The upper piston: passo 3, immagine 3 di 3
    • He is held in place by four latches. These impress, e.g. with a screwdriver, then the piston can be pushed down.
    • The new sealing ring is already waiting, but first it has to be cleaned properly.
  4. Saeco Royal brewing unit disassembly, Intake: passo 4, immagine 1 di 3 Saeco Royal brewing unit disassembly, Intake: passo 4, immagine 2 di 3 Saeco Royal brewing unit disassembly, Intake: passo 4, immagine 3 di 3
    • Through the hole on the opposite side of the fixing screw can be solved. The inlet is plugged in and held by a latch, which you have to push away.
  5. Saeco Royal brewing unit disassembly, dismantle: passo 5, immagine 1 di 3 Saeco Royal brewing unit disassembly, dismantle: passo 5, immagine 2 di 3 Saeco Royal brewing unit disassembly, dismantle: passo 5, immagine 3 di 3
    • Three screws hold the brew groups together, loosen.
    • The whole mechanics can now be broken down into three big parts. The coffee funnel can stay.
  6. Saeco Royal brewing unit disassembly, Umlenkhebel: passo 6, immagine 1 di 2 Saeco Royal brewing unit disassembly, Umlenkhebel: passo 6, immagine 2 di 2
    • That's the trickiest part: you have to lever this lever out of its camp. To do this you drive with a screwdriver between the lever and the carrier and press it really very strong outwards. Now he grabs out - hopefully!
  7. Saeco Royal brewing unit disassembly, Lower piston: passo 7, immagine 1 di 1
    • Since the lever is gone you can easily pull out the piston. It has no seal.
    • The lower piston itself has no gasket. But the shaft of the piston slides in an o-ring. which is situated under the brewing chamber. It can be changed, but it´s not easy to do this.
  8. Saeco Royal brewing unit disassembly, Clean: passo 8, immagine 1 di 1
    • That's why we did it. All parts are thoroughly cleaned. For this purpose, a solution of machine detergent is good. (Use rubber gloves!) Clean all channels with pipe cleaners. The brewing sieve is like new again! Allow to dry well.
    • Then apply new gaskets, in particular to the crema valve and piston and lubricate with food-grade grease.
    • Fat also belongs to the bearings of the rocker arm and into the slides, the piston skirt, as well as into the water inlet
Conclusione
Un ringraziamento speciale a questi traduttori:
de en
100%
VauWeh ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
VauWeh
Membro da: 10/19/15
171.598 Reputazione
219 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 97
Tutti i Tempi: 3,815
