Salta al contenuto principale
SG 552-1 Commando Trigger Replacement
Cosa ti serve
    1. SG 552-1 Commando Trigger Replacement, Gearbox: passo 1, immagine 1 di 2 SG 552-1 Commando Trigger Replacement, Gearbox: passo 1, immagine 2 di 2
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Remove the hand guard.
      Chiedi a FixBot
      Aggiungi Commento
    2. SG 552-1 Commando Trigger Replacement: passo 2, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 2, immagine 2 di 2
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
      • There should be four total.
      Chiedi a FixBot
      Aggiungi Commento
    3. SG 552-1 Commando Trigger Replacement: passo 3, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 3, immagine 2 di 2
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw that is located directly underneath the cocking lever.
      • Remove the 8mm screw located beside the screw you just removed.
      Chiedi a FixBot
      Aggiungi Commento
    4. SG 552-1 Commando Trigger Replacement: passo 4, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 4, immagine 2 di 2
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      Chiedi a FixBot
      Aggiungi Commento
    5. SG 552-1 Commando Trigger Replacement: passo 5, immagine 1 di 3 SG 552-1 Commando Trigger Replacement: passo 5, immagine 2 di 3 SG 552-1 Commando Trigger Replacement: passo 5, immagine 3 di 3
      • Locate the hand grip.
      • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
      • Slide the cover off.
      Chiedi a FixBot
      Aggiungi Commento
    6. SG 552-1 Commando Trigger Replacement: passo 6, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 6, immagine 2 di 2
      • Pull the motor out of the hand grip.
      • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
      Chiedi a FixBot
      Aggiungi Commento
    7. SG 552-1 Commando Trigger Replacement: passo 7, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 7, immagine 2 di 2
      • Locate the pin holding the folding stock in place.
      • Using an allen wrench or something small, carefully push the pin out.
      Chiedi a FixBot
      Aggiungi Commento
    8. SG 552-1 Commando Trigger Replacement: passo 8, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 8, immagine 2 di 2
      • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
      • Remove the cover that was held on by the screw.
      Chiedi a FixBot
      Aggiungi Commento
    9. SG 552-1 Commando Trigger Replacement: passo 9, immagine 1 di 3 SG 552-1 Commando Trigger Replacement: passo 9, immagine 2 di 3 SG 552-1 Commando Trigger Replacement: passo 9, immagine 3 di 3
      • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
      • Slide off the piece that was held on by those screws.
      Chiedi a FixBot
      Aggiungi Commento
    10. SG 552-1 Commando Trigger Replacement: passo 10, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 10, immagine 2 di 2
      • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
      • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
      Chiedi a FixBot
      Aggiungi Commento
    11. SG 552-1 Commando Trigger Replacement: passo 11, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 11, immagine 2 di 2
      • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
      • Carefully remove the pieces that were held on by the screws.
      Chiedi a FixBot
      Aggiungi Commento
    12. SG 552-1 Commando Trigger Replacement: passo 12, immagine 1 di 3 SG 552-1 Commando Trigger Replacement: passo 12, immagine 2 di 3 SG 552-1 Commando Trigger Replacement: passo 12, immagine 3 di 3
      • Pull apart the cover when pulling the gearbox out.
      • Pull the gearbox out.
      • The gears will fall out when taking the gearbox out. Careful not to lose them.
      Chiedi a FixBot
      Aggiungi Commento
    1. SG 552-1 Commando Trigger Replacement, Trigger: passo 13, immagine 1 di 2 SG 552-1 Commando Trigger Replacement, Trigger: passo 13, immagine 2 di 2
      • Remove these four 15mm screws.
      • Remove this single 8mm screw.
      • Using a Phillips #0 screwdriver, remove the following screws:
      • Remove this single 14mm screw.
      • Remove this single 3mm screw.
      • Detach the pieces unscrewed from the gearbox.
      Chiedi a FixBot
      Aggiungi Commento
    2. SG 552-1 Commando Trigger Replacement: passo 14, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 14, immagine 2 di 2
      • Remove the cover over the trigger.
      • Remove the safety piece.
      • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
      Chiedi a FixBot
      Aggiungi Commento
    3. SG 552-1 Commando Trigger Replacement: passo 15, immagine 1 di 2 SG 552-1 Commando Trigger Replacement: passo 15, immagine 2 di 2
      • Remove the metal piece.
      • Removal of this piece will permanently damage the metal piece.
      • Remove the cover for the gearbox.
      Chiedi a FixBot
      Aggiungi Commento
    4. SG 552-1 Commando Trigger Replacement: passo 16, immagine 1 di 1
      • Pull the trigger off the gearbox.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Anika Morris
Membro da: 10/05/12
1 Reputazione
4 guide realizzate
Cal Poly, Team 18-41, Regan Fall 2012 Membro di Cal Poly, Team 18-41, Regan Fall 2012
CPSU-REGAN-F12S18G41
6 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 34
Tutti i Tempi: 2,055
