Salta al contenuto principale
Ryobi P235 Direction of Rotation Selector Replacement
Cosa ti serve
    1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: passo 1, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement, Battery: passo 1, immagine 2 di 2
      • Push in both push tabs on the battery at the same time.
      • They are located below the green housing and are in the middle on both sides of the battery.
      Chiedi a FixBot
      Aggiungi Commento
    2. Ryobi P235 Direction of Rotation Selector Replacement: passo 2, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 2, immagine 2 di 2
      • Pull the battery away from the drill housing while holding in both tabs.
      Chiedi a FixBot
      Aggiungi Commento
    1. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 3, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: passo 3, immagine 2 di 2
      • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
      Chiedi a FixBot
      Aggiungi Commento
    2. Ryobi P235 Direction of Rotation Selector Replacement: passo 4, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 4, immagine 2 di 2
      • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
      Chiedi a FixBot
      Aggiungi Commento
    3. Ryobi P235 Direction of Rotation Selector Replacement: passo 5, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 5, immagine 2 di 2
      • Open the housing with the data label facing up.
      Chiedi a FixBot
      Aggiungi Commento
    4. Ryobi P235 Direction of Rotation Selector Replacement: passo 6, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 6, immagine 2 di 2
      • Lift the internal components out of the housing.
      Chiedi a FixBot
      Aggiungi Commento
    5. Ryobi P235 Direction of Rotation Selector Replacement: passo 7, immagine 1 di 2 Ryobi P235 Direction of Rotation Selector Replacement: passo 7, immagine 2 di 2
      • Remove the gray plastic forward/reverse selector.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 10
Ultimi 30 giorni: 39
Tutti i Tempi: 1,337
