Salta al contenuto principale
Roku 4 Remote Control Motherboard Replacement
Cosa ti serve
    1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: passo 1, immagine 1 di 1
      • Place the remote control facing down on the table, so that the buttons are facing downwards.
      Chiedi a FixBot
      Aggiungi Commento
    2. Roku 4 Remote Control Motherboard Replacement: passo 2, immagine 1 di 2 Roku 4 Remote Control Motherboard Replacement: passo 2, immagine 2 di 2
      • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
      Chiedi a FixBot
      Aggiungi Commento
    3. Roku 4 Remote Control Motherboard Replacement: passo 3, immagine 1 di 2 Roku 4 Remote Control Motherboard Replacement: passo 3, immagine 2 di 2
      • Remove the batteries from the battery compartment.
      Chiedi a FixBot
      Aggiungi Commento
    4. Roku 4 Remote Control Motherboard Replacement: passo 4, immagine 1 di 1
      • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
      Chiedi a FixBot
      Aggiungi Commento
    5. Roku 4 Remote Control Motherboard Replacement: passo 5, immagine 1 di 1
      • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
      • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
      • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
      Chiedi a FixBot
      Aggiungi Commento
    6. Roku 4 Remote Control Motherboard Replacement: passo 6, immagine 1 di 3 Roku 4 Remote Control Motherboard Replacement: passo 6, immagine 2 di 3 Roku 4 Remote Control Motherboard Replacement: passo 6, immagine 3 di 3
      • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team S5-G4, Williams Spring 2017 Membro di Baylor, Team S5-G4, Williams Spring 2017
BU-WILLIAMS-S17S5G4
3 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 14
Ultimi 30 giorni: 42
Tutti i Tempi: 2,118
