Salta al contenuto principale
Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
Cosa ti serve
  1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: passo 1, immagine 1 di 1
    • Remove the 4 rubber tabs on the bottom side of the receiver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 2, immagine 1 di 1
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
    Chiedi a FixBot
    Aggiungi Commento
  3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 3, immagine 1 di 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 3, immagine 2 di 2
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
    Chiedi a FixBot
    Aggiungi Commento
  4. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: passo 4, immagine 1 di 1
    • Unscrew the 10 mm screw holding the wireless audio module.
    Chiedi a FixBot
    Aggiungi Commento
  5. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 5, immagine 1 di 2 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 5, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    • Slide the black retaining flap securing the ribbon cable away from the white bar.
    • There should be only a small space between the white bar and black retaining flap.
    • You may want to use tweezers for this step.
    Chiedi a FixBot
    Aggiungi Commento
  6. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: passo 6, immagine 1 di 1
    • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To install the new wireless audio module chip, follow these instructions in reverse order.
Baylor, Team 4-2, Williams Spring 2015 Membro di Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Membri
12 guide realizzate
1Commento della guida
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 28
Tutti i Tempi: 2,550
