Salta al contenuto principale
Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement
Cosa ti serve
    1. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: passo 1, immagine 1 di 1
      • Remove the 4 rubber tabs on the bottom side of the receiver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: passo 2, immagine 1 di 1
      • Unscrew the four 12 mm screws on the bottom side of the receiver.
      • Use a Phillips #1 screwdriver for this step.
      Chiedi a FixBot
      Aggiungi Commento
    3. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: passo 3, immagine 1 di 2 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: passo 3, immagine 2 di 2
      • Remove top casing from the receiver.
      • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
      Chiedi a FixBot
      Aggiungi Commento
    1. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: passo 4, immagine 1 di 2 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: passo 4, immagine 2 di 2
      • One 10 mm screw is securing the LED 14.14 chip.
      • Unscrew the chip.
      • Use a Phillips #1 Screwdriver for this step.
      Chiedi a FixBot
      Aggiungi Commento
    2. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: passo 5, immagine 1 di 1
      • Using your fingers, gently pull the LED plug out of the mother board.
      Chiedi a FixBot
      Aggiungi Commento
    3. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: passo 6, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Gently feed the LED wire under the power supply to completely remove it from the sender.
      • Remove the faulty LED 14.14 chip from the receiver.
      • You may want to use the tweezers to help pull the LED wire out from beneath the power supply.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device with the new LED light chip, follow these instructions in reverse order.
Once the receiver has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new LED light chip has been properly assembled.
Baylor, Team 4-2, Williams Spring 2015 Membro di Baylor, Team 4-2, Williams Spring 2015
BU-WILLIAMS-S15S4G2
3 Membri
12 guide realizzate
2Commenti sulla guida
Where do I get the chip???
sean moore - Rispondi Condividi
where do I get chip?
bugsyc26 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 23
Tutti i Tempi: 2,497
