Salta al contenuto principale
Ring Outdoor Security Cam Infrared Sensor Replacement
Cosa ti serve
    1. Ring Outdoor Security Cam Infrared Sensor Replacement, Infrared Sensor: passo 1, immagine 1 di 1
      • Remove the six 6 mm Phillips #00 screws from the back on the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 2, immagine 1 di 1
      • Pry off the aluminum plate using a plastic opening tool.
      Chiedi a FixBot
      Aggiungi Commento
    3. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 3, immagine 1 di 1
      • Using the same tool pry the back plate off of the device.
      Chiedi a FixBot
      Aggiungi Commento
    4. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 4, immagine 1 di 1
      • Disconnect the battery power leads using a plastic opening tool.
      Chiedi a FixBot
      Aggiungi Commento
    5. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 5, immagine 1 di 1
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      Chiedi a FixBot
      Aggiungi Commento
    6. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 6, immagine 1 di 1
      • Disconnect the ribbon cable carefully at the bottom of the device.
      • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    7. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 7, immagine 1 di 1
      • Pull the top of the motherboard up and out of the device.
      Chiedi a FixBot
      Aggiungi Commento
    8. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 8, immagine 1 di 2 Ring Outdoor Security Cam Infrared Sensor Replacement: passo 8, immagine 2 di 2
      • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
      • Remove the 3 plastic spacers on the device.
      Chiedi a FixBot
      Aggiungi Commento
    9. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 9, immagine 1 di 3 Ring Outdoor Security Cam Infrared Sensor Replacement: passo 9, immagine 2 di 3 Ring Outdoor Security Cam Infrared Sensor Replacement: passo 9, immagine 3 di 3
      • Pry the motherboard out with a plastic opening tool.
      • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
      Chiedi a FixBot
      Aggiungi Commento
    10. Ring Outdoor Security Cam Infrared Sensor Replacement: passo 10, immagine 1 di 1
      • Using a soldering iron to disconnect the connections.
      • Remove the infrared sensor and replace as needed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 36
Tutti i Tempi: 597
