Salta al contenuto principale
Revlon One-Step Hair Dryer Setting Dial Replacement
Cosa ti serve
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Barrel: passo 1, immagine 1 di 1
      • First, remove the pink panels on each side of the handle in order to access the screws.
      • Use the iFixit opening tool to remove the pink panels.
      Chiedi a FixBot
      Aggiungi Commento
    2. Revlon One-Step Hair Dryer Setting Dial Replacement: passo 2, immagine 1 di 3 Revlon One-Step Hair Dryer Setting Dial Replacement: passo 2, immagine 2 di 3 Revlon One-Step Hair Dryer Setting Dial Replacement: passo 2, immagine 3 di 3
      • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
      • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
      • Next, completely remove the screws out of the dryer handle.
      Chiedi a FixBot
      Aggiungi Commento
    3. Revlon One-Step Hair Dryer Setting Dial Replacement: passo 3, immagine 1 di 3 Revlon One-Step Hair Dryer Setting Dial Replacement: passo 3, immagine 2 di 3 Revlon One-Step Hair Dryer Setting Dial Replacement: passo 3, immagine 3 di 3
      • Remove the barrel by twisting and pulling it away from the handle of the dryer.
      • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
      Chiedi a FixBot
      Aggiungi Commento
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: passo 4, immagine 1 di 2 Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: passo 4, immagine 2 di 2
      • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
      Chiedi a FixBot
      Aggiungi Commento
    2. Revlon One-Step Hair Dryer Setting Dial Replacement: passo 5, immagine 1 di 1
      • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
      • Store screws in a safe place, you will need them to reassemble the device later.
      Chiedi a FixBot
      Aggiungi Commento
    3. Revlon One-Step Hair Dryer Setting Dial Replacement: passo 6, immagine 1 di 1
      • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
      Chiedi a FixBot
      Aggiungi Commento
    4. Revlon One-Step Hair Dryer Setting Dial Replacement: passo 7, immagine 1 di 3 Revlon One-Step Hair Dryer Setting Dial Replacement: passo 7, immagine 2 di 3 Revlon One-Step Hair Dryer Setting Dial Replacement: passo 7, immagine 3 di 3
      • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
      • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
      • Next with your free hand carefully pull the cord out of the port of the dryer handle.
      Chiedi a FixBot
      Aggiungi Commento
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Setting Dial: passo 8, immagine 1 di 1
      • Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
2Commenti sulla guida
Referring to step 4, how do you release the first part with the metal mesh inside from the body
Richard Funnell - Rispondi Condividi
This video shows very good how to dissamble the hairdryer. https://youtu.be/Qc-jcJbNQzE?si=wibfeCDW...
Tobi - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 24
Ultimi 30 giorni: 73
Tutti i Tempi: 6,952
