Salta al contenuto principale
Retroid Pocket 3 Trigger Button Replacement
Cosa ti serve
  1. Retroid Pocket 3 Trigger Button Replacement, Battery: passo 1, immagine 1 di 1
    • Unplug any cables connected to the Retroid Pocket 3+.
    • Ensure your device has a charge of 5% or less as a charged battery can be dangerous if punctured.
    Chiedi a FixBot
    Aggiungi Commento
  2. Retroid Pocket 3 Trigger Button Replacement: passo 2, immagine 1 di 3 Retroid Pocket 3 Trigger Button Replacement: passo 2, immagine 2 di 3 Retroid Pocket 3 Trigger Button Replacement: passo 2, immagine 3 di 3
    • Remove the four 6 mm screws from the backplate of the device with a T5 Torx screwdriver.
    • Use a plastic opening tool or spudger to gently pry apart the backplate from the device.
    Chiedi a FixBot
    Aggiungi Commento
  3. Retroid Pocket 3 Trigger Button Replacement: passo 3, immagine 1 di 2 Retroid Pocket 3 Trigger Button Replacement: passo 3, immagine 2 di 2
    • Remove the four 4.5 mm screws with a Phillips #00 screwdriver.
    • Lift off the metal plate.
    Chiedi a FixBot
    Aggiungi Commento
  4. Retroid Pocket 3 Trigger Button Replacement: passo 4, immagine 1 di 3 Retroid Pocket 3 Trigger Button Replacement: passo 4, immagine 2 di 3 Retroid Pocket 3 Trigger Button Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool or spudger to unclip the battery connector.
    • Carefully lift the battery from the case.
    • The battery has double-sided tape at the bottom. Gently push a spudger or opening tool underneath the battery to help free it from the adhesive. Do not bend or puncture the battery.
    • Lift and remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. Retroid Pocket 3 Trigger Button Replacement, Trigger Button: passo 5, immagine 1 di 3 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: passo 5, immagine 2 di 3 Retroid Pocket 3 Trigger Button Replacement, Trigger Button: passo 5, immagine 3 di 3
    • Using the spudger, put the tip under the top round clip at the top.
    • Carefully start lifting the clip to slide it off the plastic pin on the case, tilting the trigger button as you lift it to remove.
    Chiedi a FixBot
    Aggiungi Commento
  6. Retroid Pocket 3 Trigger Button Replacement: passo 6, immagine 1 di 3 Retroid Pocket 3 Trigger Button Replacement: passo 6, immagine 2 di 3 Retroid Pocket 3 Trigger Button Replacement: passo 6, immagine 3 di 3
    • Remove the six 4.4 mm screws on the trigger buttons with a Phillips #00 screwdriver.
    • Gently pull the trigger button through until it has come undone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 70
Tutti i Tempi: 1,561
