Salta al contenuto principale
RetroMini Miyoo Mini Plus Screen Replacement
Cosa ti serve
  1. RetroMini Miyoo Mini Plus Screen Replacement, Battery: passo 1, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
  2. RetroMini Miyoo Mini Plus Screen Replacement: passo 2, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement: passo 2, immagine 2 di 2
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
  3. RetroMini Miyoo Mini Plus Screen Replacement: passo 3, immagine 1 di 1
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
  4. RetroMini Miyoo Mini Plus Screen Replacement: passo 4, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement: passo 4, immagine 2 di 2
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
  5. RetroMini Miyoo Mini Plus Screen Replacement: passo 5, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement: passo 5, immagine 2 di 2
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
  6. RetroMini Miyoo Mini Plus Screen Replacement, Button: passo 6, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement, Button: passo 6, immagine 2 di 2
    • Remove the four screws securing the rear case with a Phillips screwdriver.
    • Remove the two Phillips screws inside the battery compartment.
  7. RetroMini Miyoo Mini Plus Screen Replacement: passo 7, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement: passo 7, immagine 2 di 2
    • Insert an opening tool into the seam between the front and rear case.
    • Pry the front and rear case apart.
  8. RetroMini Miyoo Mini Plus Screen Replacement: passo 8, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement: passo 8, immagine 2 di 2
    • Gently set the rear case aside.
    • Make sure you lift the black tab on the left side of the motherboard and gently remove the ribbon cable as to not damage it when removing the motherboard from the case.
  9. RetroMini Miyoo Mini Plus Screen Replacement: passo 9, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement: passo 9, immagine 2 di 2
    • Use an opening tool to lift the motherboard from the chassis.
  10. RetroMini Miyoo Mini Plus Screen Replacement: passo 10, immagine 1 di 3 RetroMini Miyoo Mini Plus Screen Replacement: passo 10, immagine 2 di 3 RetroMini Miyoo Mini Plus Screen Replacement: passo 10, immagine 3 di 3
    • Gently set the motherboard to the side.
    • Remove the rubber button gasket.
  11. RetroMini Miyoo Mini Plus Screen Replacement: passo 11, immagine 1 di 1
    • Remove the button(s) you want to replace.
  12. RetroMini Miyoo Mini Plus Screen Replacement, Screen: passo 12, immagine 1 di 1
    • Heat an iOpener according to the instructions here.
    • Rest the iOpener Gel Bag on the screen for a minute.
    • Alternatively, use a hair dryer to gently heat the screen to loosen the adhesive that secures it.
  13. RetroMini Miyoo Mini Plus Screen Replacement: passo 13, immagine 1 di 2 RetroMini Miyoo Mini Plus Screen Replacement: passo 13, immagine 2 di 2
    • Gently apply pressure to the highlighted area on the front cover of the device.
    • While applying the pressure gently peel the screen off of the device.
    • Take care not to flex the screen. If the screen feels stubborn, apply more heat.
  14. RetroMini Miyoo Mini Plus Screen Replacement: passo 14, immagine 1 di 3 RetroMini Miyoo Mini Plus Screen Replacement: passo 14, immagine 2 di 3 RetroMini Miyoo Mini Plus Screen Replacement: passo 14, immagine 3 di 3
    • Set the new screen gently into the ridges (boxed in red) on the front of the backlit screen
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 110
Tutti i Tempi: 1,267
