Salta al contenuto principale
Retro-Bit Retro Duo Reset Button/Power Switch Replacement
Cosa ti serve
  1. Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: passo 1, immagine 1 di 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: passo 1, immagine 2 di 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement, Reset Button/Power Switch: passo 1, immagine 3 di 3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one, or more, of the screws. Simply remove the it before the screws.
    • Flip the console on its feet and carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not completely remove the top case. There is a small circuit board--which houses two LEDs-- connected to the main circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  2. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 2, immagine 1 di 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 2, immagine 2 di 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 2, immagine 3 di 3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case.
    • This step allows easy button access and prevents accidental damage.
    Chiedi a FixBot
    Aggiungi Commento
  3. Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 3, immagine 1 di 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 3, immagine 2 di 3 Retro-Bit Retro Duo Reset Button/Power Switch Replacement: passo 3, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Using your fingers (or precision tweezers), carefully pinch the button tabs and push through to the other side.
    • Make sure you pinch both tabs simultaneously, or the button will not pop out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
If the problem persists after the buttons are replaced, it may be a circuit board issue. If so, please visit our guide for circuit board replacement at Retro-Bit Retro Duo Circuit Board Replacement
Truong Vo
Membro da: 09/25/17
324 Reputazione
3 guide realizzate
USF Tampa, Team S4-G4, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 40
Tutti i Tempi: 1,262
