Salta al contenuto principale
Replacing VTech MobiGo Touch Learning System Speaker
Cosa ti serve
    1. Replacing VTech MobiGo Touch Learning System Speaker, Case: passo 1, immagine 1 di 1
      • Remove the battery covers and the four batteries.
      Chiedi a FixBot
      Aggiungi Commento
    2. Replacing VTech MobiGo Touch Learning System Speaker: passo 2, immagine 1 di 2 Replacing VTech MobiGo Touch Learning System Speaker: passo 2, immagine 2 di 2
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Chiedi a FixBot
      Aggiungi Commento
    3. Replacing VTech MobiGo Touch Learning System Speaker: passo 3, immagine 1 di 2 Replacing VTech MobiGo Touch Learning System Speaker: passo 3, immagine 2 di 2
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Chiedi a FixBot
      Aggiungi Commento
    1. Replacing VTech MobiGo Touch Learning System Speaker, Speaker: passo 4, immagine 1 di 2 Replacing VTech MobiGo Touch Learning System Speaker, Speaker: passo 4, immagine 2 di 2
      • The speaker will be attached to the back of the case.
      • Unscrew the two 6.0 mm Philips J0 screws.
      • Careful! The wires are still attached to the back of the case and to the speakers.
      Chiedi a FixBot
      Aggiungi Commento
    2. Replacing VTech MobiGo Touch Learning System Speaker: passo 5, immagine 1 di 2 Replacing VTech MobiGo Touch Learning System Speaker: passo 5, immagine 2 di 2
      • Lift the round speaker with a plastic opening tool.
      • Remove the two wires connected to the speaker.
      • You can use wire cutters or regular needle nose pliers to disconnect the wires from the speaker.
      • Once the wires are disconnected, remove the speaker from the back of the case.
      Chiedi a FixBot
      Aggiungi Commento
    3. Replacing VTech MobiGo Touch Learning System Speaker: passo 6, immagine 1 di 2 Replacing VTech MobiGo Touch Learning System Speaker: passo 6, immagine 2 di 2
      • Solder the wires to the appropriate spots on the new speaker, making sure that both wires are properly connected.
      • The wires may be hot.
      Chiedi a FixBot
      Aggiungi Commento
    4. Replacing VTech MobiGo Touch Learning System Speaker: passo 7, immagine 1 di 2 Replacing VTech MobiGo Touch Learning System Speaker: passo 7, immagine 2 di 2
      • Insert the new speaker into the hatch located in the middle part of the panel using a plastic spudger.
      • Make sure the speaker is the right size for the panel.
      • Once the speaker is properly placed, screw in the two 6.0 mm Philips J0 screws.
      • Do not over tighten the screws or the panel will break.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your case, follow the case instructions in reverse order.
RBansil
Membro da: 08/27/15
221 Reputazione
2 guide realizzate
USF Tampa, Team 8-3, Eyestone Fall 2015 Membro di USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Membri
17 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 33
Tutti i Tempi: 2,202
