Salta al contenuto principale
Replacing Creative Zen X-Fi Battery
Cosa ti serve
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: passo 1, immagine 1 di 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: passo 1, immagine 2 di 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: passo 1, immagine 3 di 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
    Chiedi a FixBot
    Aggiungi Commento
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: passo 2, immagine 1 di 1
    • The black rubber button pad can be removed by simply picking it up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: passo 3, immagine 1 di 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
    Chiedi a FixBot
    Aggiungi Commento
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: passo 4, immagine 1 di 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
    Chiedi a FixBot
    Aggiungi Commento
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: passo 5, immagine 1 di 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
    Chiedi a FixBot
    Aggiungi Commento
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: passo 6, immagine 1 di 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
    Chiedi a FixBot
    Aggiungi Commento
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: passo 7, immagine 1 di 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
    Chiedi a FixBot
    Aggiungi Commento
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: passo 8, immagine 1 di 1
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
    Chiedi a FixBot
    Aggiungi Commento
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: passo 9, immagine 1 di 2 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: passo 9, immagine 2 di 2
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
2Commenti sulla guida
very clear pictures!
John - Rispondi Condividi
разбирать нужно со стороны противоположной гнезда наушников!!! поломал так же как и на фото все защелки со стороны кнопок(
Cooper21 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 19
Ultimi 30 giorni: 93
Tutti i Tempi: 8,786
