Salta al contenuto principale
Repairing Display
Cosa ti serve
    1. Repairing Display, Display: passo 1, immagine 1 di 1
      • Remove the 6 outer screws on the underside of the laptop.
      • Open the battery compartment and remove the 7 visible screws.
      • Pry the corners of the bezel at the base of the keyboard, pushing up until it loosens.
      • Carefully remove the ribbon connections of the keyboard, power button, and wifi button.
      • Disconnect and re-connect the white monitor ribbon located on the left side to make sure it sits firmly in the connection.
      • Reassemble the laptop by following these steps in reverse.
      • The monitor should work when powered on again.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 10 persone hanno completato questa guida.
duncan
Membro da: 06/28/12
247 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 8
Ultimi 30 giorni: 47
Tutti i Tempi: 12,966
