Salta al contenuto principale
Questa traduzione potrebbe non riflettere gli aggiornamenti più recenti dalla guida originale. Aiuta ad aggiornare la traduzione o visualizza la guida d'origine.
Repair electronics
    • Seen from below, the handpiece is oval-shaped. Wrap with a cloth, with a pair of pliers, a nutcracker or similar. start where the feet are and put the oval in a circle. At the same time, press the handpiece upside down, ie with the metal shank in front, onto a wooden base, whereby the inner life is expelled.
    Chiedi a FixBot
    Aggiungi Commento
  1. Repair electronics, Remove handpiece base: passo 2, immagine 1 di 1
    • Remove the underside of the handpiece by carefully lifting the tabs at the two farthest vertexes of the oval with a small screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Repair electronics, Remove the rubber pad from the motherboard: passo 3, immagine 1 di 1
    • Remove the rubber pad from the motherboard
    Chiedi a FixBot
    Aggiungi Commento
  3. Repair electronics, Remove plastic cap from metal shaft: passo 4, immagine 1 di 1
    • Use a puller to remove the plastic cap from the metal shaft to expose the defective rubber boot.
    Chiedi a FixBot
    Aggiungi Commento
    • Thoroughly clean all housing parts with water and cloth.
    • Thoroughly clean the electronics and mechanics with isopropyl alcohol and a fine brush.
    • Also completely rid the metal shaft of any residue.
    Chiedi a FixBot
    Aggiungi Commento
  4. Repair electronics, Repair electronics: passo 6, immagine 1 di 1
    • Place the inner workings of the handpiece without housing parts in a container in such a way that the main board points downwards and the battery points upwards.
    • Now fill the container with isopropyl alcohol just enough so that the liquid level reaches the circuit board.
    • Leave to stand for 1-2 hours under supervision, then remove the device from the liquid bath and allow to dry.
    Chiedi a FixBot
    Aggiungi Commento
  5. Repair electronics, Replace rubber sleeve: passo 7, immagine 1 di 1
    • The defective rubber sleeve on the metal shaft must be replaced. A spare part is available for less than € 4 on eBay under the following designation: "Philips electric toothbrush Waterproof sealing parts for HX6730 HX6930 HX9340».
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repeat the steps in order to reassemble your device.
Un ringraziamento speciale a questi traduttori:
de en
94%
irlanda ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Gerd Conzetti
Membro da: 11/12/17
319 Reputazione
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 60
Tutti i Tempi: 1,771
