Salta al contenuto principale
Removing Olympus FE-210 Flash Assembly
Cosa ti serve
    1. Removing Olympus FE-210 Flash Assembly, Battery: passo 1, immagine 1 di 2 Removing Olympus FE-210 Flash Assembly, Battery: passo 1, immagine 2 di 2
      • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
      Chiedi a FixBot
      Aggiungi Commento
    2. Removing Olympus FE-210 Flash Assembly: passo 2, immagine 1 di 2 Removing Olympus FE-210 Flash Assembly: passo 2, immagine 2 di 2
      • The batteries will slide right out.
      • When putting new batteries in, make sure they are pointing the right direction.
      Chiedi a FixBot
      Aggiungi Commento
    1. Removing Olympus FE-210 Flash Assembly, Front Casing: passo 3, immagine 1 di 3 Removing Olympus FE-210 Flash Assembly, Front Casing: passo 3, immagine 2 di 3 Removing Olympus FE-210 Flash Assembly, Front Casing: passo 3, immagine 3 di 3
      • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
      • Six screws are 3.6 mm.
      • The seventh screw is 3.2 mm.
      Chiedi a FixBot
      Aggiungi Commento
    2. Removing Olympus FE-210 Flash Assembly: passo 4, immagine 1 di 3 Removing Olympus FE-210 Flash Assembly: passo 4, immagine 2 di 3 Removing Olympus FE-210 Flash Assembly: passo 4, immagine 3 di 3
      • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
      • These three places are located:
      • At the top and bottom of the battery side (opposite of side pictured) of the case.
      • Right in the middle of the DC-in side (side pictured) of the case.
      • Top of the camera, to the left of the power button.
      • Once those places are disconnected, the front case will pop right off.
      • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
      Chiedi a FixBot
      Aggiungi Commento
    1. Removing Olympus FE-210 Flash Assembly, Rear Casing: passo 5, immagine 1 di 1
      • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
      • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Removing Olympus FE-210 Flash Assembly: passo 6, immagine 1 di 3 Removing Olympus FE-210 Flash Assembly: passo 6, immagine 2 di 3 Removing Olympus FE-210 Flash Assembly: passo 6, immagine 3 di 3
      • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
      • Lift the white latch using a fingernail or a spudger.
      • Pull the cord from its connector.
      Chiedi a FixBot
      Aggiungi Commento
    1. Removing Olympus FE-210 Flash Assembly, Flash Assembly: passo 7, immagine 1 di 2 Removing Olympus FE-210 Flash Assembly, Flash Assembly: passo 7, immagine 2 di 2
      • Remove the two 2.7 mm screws using a #00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Removing Olympus FE-210 Flash Assembly: passo 8, immagine 1 di 2 Removing Olympus FE-210 Flash Assembly: passo 8, immagine 2 di 2
      • Remove the metal casing on the flash, by grabbing with two fingers and pry it off the snaps connecting it to the flash.
      • Remove the plastic cover on the flash, by simply grabbing the plastic with two fingers and pulling.
      Chiedi a FixBot
      Aggiungi Commento
    3. Removing Olympus FE-210 Flash Assembly: passo 9, immagine 1 di 2 Removing Olympus FE-210 Flash Assembly: passo 9, immagine 2 di 2
      • Remove the 2.7 mm screw holding the front circuit board in place.
      Chiedi a FixBot
      Aggiungi Commento
    4. Removing Olympus FE-210 Flash Assembly: passo 10, immagine 1 di 3 Removing Olympus FE-210 Flash Assembly: passo 10, immagine 2 di 3 Removing Olympus FE-210 Flash Assembly: passo 10, immagine 3 di 3
      • Remove the circuit board by prying it out with a spudger.
      • Remove the flashbulb from its place.
      • When taking out the flash bulb, be sure to carefully remove the wire taped to the back of the bulb (as shown in the second image). Gently separate the tape and the wire.
      Chiedi a FixBot
      Aggiungi Commento
    5. Removing Olympus FE-210 Flash Assembly: passo 11, immagine 1 di 3 Removing Olympus FE-210 Flash Assembly: passo 11, immagine 2 di 3 Removing Olympus FE-210 Flash Assembly: passo 11, immagine 3 di 3
      • To remove the capacitor you must slide it out from the sticky tape that is holding it in place.
      • First insert a spudger between the capacitor and the plastic.
      • Pry with the spudger or pull with your hands to loosen the capacitor.
      • Capacitors can contain a lot of energy. If you touch the terminals you could get a strong shock. So be careful to avoid the terminals with your fingers and don't use any metal tools to interact with the capacitor.
      • The capacitor can be difficult to loosen at first, give it strong pulls and pushes and it should come out.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Matt
Membro da: 01/25/11
826 Reputazione
6 guide realizzate
Cal Poly, Team 4-36, Regan Winter 2011 Membro di Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 32
Tutti i Tempi: 3,095
