Salta al contenuto principale
Removing LG VX8350 Screen Assembly
Cosa ti serve
  1. Removing LG VX8350  Screen Assembly, Battery: passo 1, immagine 1 di 2 Removing LG VX8350  Screen Assembly, Battery: passo 1, immagine 2 di 2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Removing LG VX8350  Screen Assembly: passo 2, immagine 1 di 2 Removing LG VX8350  Screen Assembly: passo 2, immagine 2 di 2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. Removing LG VX8350  Screen Assembly, Circuit Board Housing: passo 3, immagine 1 di 3 Removing LG VX8350  Screen Assembly, Circuit Board Housing: passo 3, immagine 2 di 3 Removing LG VX8350  Screen Assembly, Circuit Board Housing: passo 3, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
    Chiedi a FixBot
    Aggiungi Commento
  4. Removing LG VX8350  Screen Assembly: passo 4, immagine 1 di 2 Removing LG VX8350  Screen Assembly: passo 4, immagine 2 di 2
    • Lift the back cover starting at the bottom of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  5. Removing LG VX8350  Screen Assembly: passo 5, immagine 1 di 2 Removing LG VX8350  Screen Assembly: passo 5, immagine 2 di 2
    • Remove the back cover completely from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  6. Removing LG VX8350  Screen Assembly, Circuit Board: passo 6, immagine 1 di 1
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
    Chiedi a FixBot
    Aggiungi Commento
  7. Removing LG VX8350  Screen Assembly: passo 7, immagine 1 di 2 Removing LG VX8350  Screen Assembly: passo 7, immagine 2 di 2
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
    Chiedi a FixBot
    Aggiungi Commento
  8. Removing LG VX8350  Screen Assembly, Keypad: passo 8, immagine 1 di 2 Removing LG VX8350  Screen Assembly, Keypad: passo 8, immagine 2 di 2
    • Lift the keyboard and remove it from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  9. Removing LG VX8350  Screen Assembly, Screen Cover: passo 9, immagine 1 di 3 Removing LG VX8350  Screen Assembly, Screen Cover: passo 9, immagine 2 di 3 Removing LG VX8350  Screen Assembly, Screen Cover: passo 9, immagine 3 di 3
    • Locate the two rubber circles covering the screws.
    • Remove the rubber covers using tweezers.
    • Using the Phillips head screwdriver, unscrew and remove the two screws.
    Chiedi a FixBot
    Aggiungi Commento
  10. Removing LG VX8350  Screen Assembly: passo 10, immagine 1 di 3 Removing LG VX8350  Screen Assembly: passo 10, immagine 2 di 3 Removing LG VX8350  Screen Assembly: passo 10, immagine 3 di 3
    • Close the phone and gently pull outwards from the bottom left portion of the phone cover.
    • Take care not to do this with too much force, as it could crack the cover.
    • Completely remove the cover from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  11. Removing LG VX8350  Screen Assembly, Screen Assembly: passo 11, immagine 1 di 2 Removing LG VX8350  Screen Assembly, Screen Assembly: passo 11, immagine 2 di 2
    • Locate the front music buttons.
    • Remove the music control buttons on the face of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  12. Removing LG VX8350  Screen Assembly: passo 12, immagine 1 di 2 Removing LG VX8350  Screen Assembly: passo 12, immagine 2 di 2
    • While grasping the top and bottom sections torque the pieces until the indicated hinge has popped out. The two sections of the phone are now able to separate.
    • Make sure the right side of the hinge is removed first and not the left as you will likely damage the ribbon connection.
    Chiedi a FixBot
    Aggiungi Commento
  13. Removing LG VX8350  Screen Assembly: passo 13, immagine 1 di 3 Removing LG VX8350  Screen Assembly: passo 13, immagine 2 di 3 Removing LG VX8350  Screen Assembly: passo 13, immagine 3 di 3
    • Locate the two speakers. Using a spudger disconnect the speakers from the assembly.
    • Lift the screen assembly from the casing.
    • The screen assembly is completely removed to allow for easier access to the speaker connections when performing further repairs on the speakers.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Clemson, Team 14-7, Benson Fall 2013 Membro di Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
3 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 32
Tutti i Tempi: 1,045
