Salta al contenuto principale
Remove the Screen
Cosa ti serve
  1. Remove the Screen, Remove Screws: passo 1, immagine 1 di 3 Remove the Screen, Remove Screws: passo 1, immagine 2 di 3 Remove the Screen, Remove Screws: passo 1, immagine 3 di 3
    • Remove the screws from the bottom, right, and left side of camera.
    Chiedi a FixBot
    Aggiungi Commento
  2. Remove the Screen, Remove back: passo 2, immagine 1 di 1
    • Remove the back of the camera, this may require force.
    Chiedi a FixBot
    Aggiungi Commento
  3. Remove the Screen, Remove Metal Bracket: passo 3, immagine 1 di 1
    • Unscrew the right metal bracket of the viewing lens
    Chiedi a FixBot
    Aggiungi Commento
  4. Remove the Screen, Remove front of camera: passo 4, immagine 1 di 2 Remove the Screen, Remove front of camera: passo 4, immagine 2 di 2
    • Hello! Today you are going to be learning how to disassemble the front camera of a Nikon Coolpix 5600. You will need a Nikon Coolpix, Ifixit opening tool and a Phillips Screwdriver #00. The first step is to pull the front of the camera off of the mother board. To do this you must pull at each side of front and back on the camera.
    Chiedi a FixBot
    Aggiungi Commento
  5. Remove the Screen: passo 5, immagine 1 di 2 Remove the Screen: passo 5, immagine 2 di 2
    • Next, pull the grey circular facet that sits on the bottom outside of the camera off by using blue Ifixit opening tool. It is okay to use force if needed.
    Chiedi a FixBot
    Aggiungi Commento
  6. Remove the Screen: passo 6, immagine 1 di 1
    • Now take your Phillips #00 screwdriver and unscrew the bottom right corner screw. Once the screw is out just place it on the table.
    Chiedi a FixBot
    Aggiungi Commento
  7. Remove the Screen: passo 7, immagine 1 di 1
    • Finally, take the same Phillips screwdriver and unscrew the top right corner screw. Place the top screw on the table as well. Now you have accurately disassembled the front camera of a Nikon Coolpix 5600.
    Chiedi a FixBot
    Aggiungi Commento
  8. Remove the Screen, Remove the Screen: passo 8, immagine 1 di 1
    • Unhinge the outer case of the screen from the back of the camera. The screen should still be hanging by wires.
    Chiedi a FixBot
    Aggiungi Commento
  9. Remove the Screen: passo 9, immagine 1 di 1
    • Remove outer case/rim of screen from the back of the camera. The screen should still be hanging by the red wire and white wire.
    Chiedi a FixBot
    Aggiungi Commento
  10. Remove the Screen: passo 10, immagine 1 di 1
    • Pull out the red wire and white wire attaching the screen to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  11. Remove the Screen: passo 11, immagine 1 di 1
    • Flip up black lever holding data cable to motherboard, and remove data cable from motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Melissa
Membro da: 02/12/13
246 Reputazione
2 guide realizzate
Ohio State, Team 1-2, Buehl Spring 2013 Membro di Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 57
Tutti i Tempi: 791
