Salta al contenuto principale
Remove Solid-State Drive (SSD)
Cosa ti serve
    1. Remove Solid-State Drive (SSD), Remove screws from bottom of laptop.: passo 1, immagine 1 di 2 Remove Solid-State Drive (SSD), Remove screws from bottom of laptop.: passo 1, immagine 2 di 2
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      Chiedi a FixBot
      Aggiungi Commento
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      Chiedi a FixBot
      Aggiungi Commento
    1. Remove Solid-State Drive (SSD), Disconnect battery cable: passo 3, immagine 1 di 1
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      Chiedi a FixBot
      Aggiungi Commento
    1. Remove Solid-State Drive (SSD), Remove the system board mylar: passo 4, immagine 1 di 2 Remove Solid-State Drive (SSD), Remove the system board mylar: passo 4, immagine 2 di 2
      • Remove the system board mylar.
      • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
      Chiedi a FixBot
      Aggiungi Commento
    1. Remove Solid-State Drive (SSD), Remove the solid-state drive (SSD) shielding: passo 5, immagine 1 di 1
      • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    1. Remove Solid-State Drive (SSD), Unscrew Solid-State Drives (SSD): passo 6, immagine 1 di 1
      • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
      Chiedi a FixBot
      Aggiungi Commento
      • Remove each SSD by pulling it away from the slot.
      • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
johann beda
Membro da: 09/13/10
3.428 Reputazione
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 29
Tutti i Tempi: 151
