Salta al contenuto principale
Remove RAM
Cosa ti serve
Documento in evidenza
  1. Remove RAM, Remove screws from bottom of laptop.: passo 1, immagine 1 di 2 Remove RAM, Remove screws from bottom of laptop.: passo 1, immagine 2 di 2
    • Flip the computer over to access the screws on the bottom.
    • Remove 8 black, 7mm PH0 screws (M2 x L7).
    • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
    Chiedi a FixBot
    Aggiungi Commento
    • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
    Chiedi a FixBot
    Aggiungi Commento
  2. Remove RAM, Disconnect battery cable: passo 3, immagine 1 di 1
    • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
    • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
    Chiedi a FixBot
    Aggiungi Commento
  3. Remove RAM, Remove battery screws: passo 4, immagine 1 di 1
    • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
    • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
    • Lift out the battery.
    Chiedi a FixBot
    Aggiungi Commento
  4. Remove RAM, Remove the system board mylar: passo 6, immagine 1 di 2 Remove RAM, Remove the system board mylar: passo 6, immagine 2 di 2
    • Remove the system board mylar.
    • Note: Retain the system board mylar and reuse it when reassembling the computer. Replace the system board mylar only if it is damaged.
    Chiedi a FixBot
    Aggiungi Commento
  5. Remove RAM, Remove the solid-state drive (SSD) shielding: passo 7, immagine 1 di 1
    • Remove 4 black PH1 screws (M2 x L4) and then remove the SSD shielding.
    Chiedi a FixBot
    Aggiungi Commento
  6. Remove RAM, Unscrew Solid-State Drives (SSD): passo 8, immagine 1 di 1
    • Remove 2 silver 2mm PH1 screws (M2 x L2), one for each SSD.
    Chiedi a FixBot
    Aggiungi Commento
    • Remove each SSD by pulling it away from the slot.
    • Note: it may be important to replace the SSDs into the same slot, so label them in some manner - perhaps "T" for the top one and "B" for the bottom one.
    Chiedi a FixBot
    Aggiungi Commento
  7. Remove RAM, Remove the Wi-Fi card: passo 10, immagine 1 di 1
    • Detach the main and auxiliary antenna cable connectors. Note which colour cable is connected to each post - the photographed board has a grey cable connected to the top post (marked as "#1 Aux" with a white triangle on the Wi-Fi card) and a black cable connected to the bottom post (marked as "#2 Main" with a black triangle on the Wi-Fi card).
    • Remove 1 silver 2mm PH1 screw (M2 x L2).
    • Remove the Wi-Fi card by pulling it away from the slot.
    Chiedi a FixBot
    Aggiungi Commento
  8. Remove RAM, Disconnect tape and cables: passo 11, immagine 1 di 1
    • (1) Peel off the thermal DIMM plate tape from the system board.
    • (2-3) Lift flap and disconnect the I/O board cable from the system board.
    • (2-3) Lift flap and disconnect the audio FPC cable from the system board.
    • (2-3) Lift flap and disconnect the hinge cap lightingbar cable from the system board.
    • Note: my machine did not have the DIMM plate tape or the cable in the upper right.
    Chiedi a FixBot
    Aggiungi Commento
  9. Remove RAM, Disconnect the fan cables: passo 12, immagine 1 di 1
    • Disconnect the three fan cables from the system board by lifting away from board.
    Chiedi a FixBot
    Aggiungi Commento
  10. Remove RAM, Remove screws and fans: passo 13, immagine 1 di 1
    • Remove 7 black 6mm PH1 screws (M2 x L6) holding the fans.
    • Remove tape from fans - possibly using gentle heat
    • Remove the fans - be careful of Wi-Fi antenna cables around top left fan and speaker cable around small bottom right fan.
    Chiedi a FixBot
    Aggiungi Commento
  11. Remove RAM, Disconnect cables: passo 14, immagine 1 di 1
    • Disconnect 9 cables connected to the system board.
    Chiedi a FixBot
    Aggiungi Commento
  12. Remove RAM, Disconnect more cables: passo 15, immagine 1 di 1
    • Disconnect five more cables from the system board
    Chiedi a FixBot
    Aggiungi Commento
    • Remove 3 black 4mm PH1 screws (M2 x L4) screws
    • Remove 2 black 6mm PH1 screws (M2 x L4) screws
    • Remove the flaps of tape holding the antenna wires to the board.
    • Remove the system board module carefully.
    Chiedi a FixBot
    Aggiungi Commento
    • Position the board over so that the heat sink tubes are on the top
    • Remove the sheet over the RAM modules.
    • Release the latches on both edges of the each socket at the same time to remove each memory module.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Documenti allegati
johann beda
Membro da: 09/13/10
3.428 Reputazione
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 18
Tutti i Tempi: 87
