Salta al contenuto principale
Remove IBM WorkPad c3 Battery
Cosa ti serve
  1. Remove IBM WorkPad c3 Battery, Back Case: passo 1, immagine 1 di 2 Remove IBM WorkPad c3 Battery, Back Case: passo 1, immagine 2 di 2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    Chiedi a FixBot
    Aggiungi Commento
  2. Remove IBM WorkPad c3 Battery: passo 2, immagine 1 di 1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Remove IBM WorkPad c3 Battery: passo 3, immagine 1 di 2 Remove IBM WorkPad c3 Battery: passo 3, immagine 2 di 2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    Chiedi a FixBot
    Aggiungi Commento
  4. Remove IBM WorkPad c3 Battery, Battery: passo 4, immagine 1 di 1
    • Remove the yellow tape that is covering the battery connector
    Chiedi a FixBot
    Aggiungi Commento
  5. Remove IBM WorkPad c3 Battery: passo 5, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Using the tweezers, carefully disconnect the battery cable from the port
    Chiedi a FixBot
    Aggiungi Commento
  6. Remove IBM WorkPad c3 Battery: passo 6, immagine 1 di 2 Remove IBM WorkPad c3 Battery: passo 6, immagine 2 di 2
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 21-35, Regan Fall 2010 Membro di Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 47
Tutti i Tempi: 4,854
