Salta al contenuto principale
Remove Battery
Cosa ti serve
    1. Remove Battery, Remove screws from bottom of laptop.: passo 1, immagine 1 di 2 Remove Battery, Remove screws from bottom of laptop.: passo 1, immagine 2 di 2
      • Flip the computer over to access the screws on the bottom.
      • Remove 8 black, 7mm PH0 screws (M2 x L7).
      • Note: Virtually all the other screws for this computer are PH1 screws which may get stripped when using a smaller screwdriver, but these screws require a Philips PH0 driver.
      Chiedi a FixBot
      Aggiungi Commento
      • Pry up the clips/latches and then remove the lower case. Start at the front (four clips), then sides (three clips each side) and back (four clips) - there is also one clip in the middle of the case.
      Chiedi a FixBot
      Aggiungi Commento
    1. Remove Battery, Disconnect battery cable: passo 3, immagine 1 di 1
      • Almost anything that is done with a computer is safer if the battery is disconnected, so it is good to do that now.
      • Disconnect the battery pack cable from the system board using fingernails or a pry bar. Use your fingernails to pull the connector to unplug it. Do not pull the cable. It can be very tight. I used a 3.5 mm flathead screwdriver to carefully push the side plastic edges down towards the battery. Do not knock any of the components on the board.
      Chiedi a FixBot
      Aggiungi Commento
    1. Remove Battery, Remove battery screws: passo 4, immagine 1 di 1
      • Remove 6 black 4mm PH1 screws (M2 x L4). The lower right screw is close to a magnet that may pull it from where you want it to go - tweezers may be necessary. The Hardware Maintenance Manual does not show the bottom middle screw.
      • Note: Virtually all the screws for this computer are PH1 screws which may get stripped if you use a smaller screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
      • Lift out the battery.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
johann beda
Membro da: 09/13/10
3.428 Reputazione
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 26
Tutti i Tempi: 137
