Salta al contenuto principale
Remington MB4040 Battery Replacement
Cosa ti serve
    1. Remington MB4040 Battery Replacement, Remove Blade Assembly: passo 1, immagine 1 di 3 Remington MB4040 Battery Replacement, Remove Blade Assembly: passo 1, immagine 2 di 3 Remington MB4040 Battery Replacement, Remove Blade Assembly: passo 1, immagine 3 di 3
      • Press the black button below the blade to remove the blade.
      Chiedi a FixBot
      Aggiungi Commento
    2. Remington MB4040 Battery Replacement, Remove Back Cover Hardware: passo 2, immagine 1 di 2 Remington MB4040 Battery Replacement, Remove Back Cover Hardware: passo 2, immagine 2 di 2
      • Place the device so the back of the product is facing up.
      • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
      Chiedi a FixBot
      Aggiungi Commento
    3. Remington MB4040 Battery Replacement, Remove Front Cover Hardware: passo 3, immagine 1 di 3 Remington MB4040 Battery Replacement, Remove Front Cover Hardware: passo 3, immagine 2 di 3 Remington MB4040 Battery Replacement, Remove Front Cover Hardware: passo 3, immagine 3 di 3
      • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
      • Remove the small clear plastic piece that covers the zoom wheel numbers.
      Chiedi a FixBot
      Aggiungi Commento
    4. Remington MB4040 Battery Replacement, Front Cover (cont.): passo 4, immagine 1 di 2 Remington MB4040 Battery Replacement, Front Cover (cont.): passo 4, immagine 2 di 2
      • Remove the two 16.0 mm PH00 screws from the front cover.
      • Use the blue plastic opening tool to pry apart the two halves of the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. Remington MB4040 Battery Replacement, Blade Button Removal: passo 5, immagine 1 di 2 Remington MB4040 Battery Replacement, Blade Button Removal: passo 5, immagine 2 di 2
      • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
      • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
      Chiedi a FixBot
      Aggiungi Commento
    1. Remington MB4040 Battery Replacement, Remove Motherboard: passo 6, immagine 1 di 2 Remington MB4040 Battery Replacement, Remove Motherboard: passo 6, immagine 2 di 2
      • Remove the four 9.0 mm PH00 screws from the motherboard.
      • Use the plastic opening tool to remove the motherboard from its housing.
      • This can be completed with the Remington MB4040 Zoom Wheel Replacement installed or removed. Just adjust the zoom wheel until it no longer covers the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Remington MB4040 Battery Replacement, Remove Battery: passo 7, immagine 1 di 3 Remington MB4040 Battery Replacement, Remove Battery: passo 7, immagine 2 di 3 Remington MB4040 Battery Replacement, Remove Battery: passo 7, immagine 3 di 3
      • Remove the thermal switch from the battery by using the spudger to pry it from the adhesive.
      • Remove the battery by desoldering the battery from the motherboard.
      • Soldering tabs hold the battery onto the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 25 persone hanno completato questa guida.
USF Tampa, Team 1-5, Blackwell Winter 2015 Membro di USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Membri
14 guide realizzate
15Commenti sulla guida
Great work - but help on where to source the battery would be good too :)
Matt Purnell - Rispondi Condividi
It's available as a generic - it's a '14500' Li-Ion battery, 3.7V - typically 750-800mAh. Dimensions: 50mm x 14mm (diameter).
I have seen two types of these batteries: protected and unprotected. Which type do we need?
Amaury C - Rispondi Condividi
You did everyrhing except the most important part to me
How did you unsolder the battery, and solder the new battery?
I was going to buy the tools from the local store but realized i don't know how to appropriately unsolder/solder battery tabs.
Non the less you are the only one who made such explanation, thank you.
Rakan - Rispondi Condividi
If you happen to lose the two springs, you can cut off 2 pieces from the spring of a pen :P
Merry Trimming & A Happy New Beard !
Mads Larsen - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 62
Ultimi 30 giorni: 253
Tutti i Tempi: 44,042
