Salta al contenuto principale
RazorX DLX Electric Skateboard Control Module Replacement
Cosa ti serve
  1. RazorX DLX Electric Skateboard Control Module Replacement, Battery: passo 1, immagine 1 di 3 RazorX DLX Electric Skateboard Control Module Replacement, Battery: passo 1, immagine 2 di 3 RazorX DLX Electric Skateboard Control Module Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the skateboard upside down.
    • Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
    • Push the cover forward to slide it off.
  2. RazorX DLX Electric Skateboard Control Module Replacement: passo 2, immagine 1 di 1
    • Disconnect the battery and slide it out.
    • Lithium-ion batteries should not be punctured, heated or improperly disposed of.
  3. RazorX DLX Electric Skateboard Control Module Replacement, Control Module: passo 3, immagine 1 di 3 RazorX DLX Electric Skateboard Control Module Replacement, Control Module: passo 3, immagine 2 di 3 RazorX DLX Electric Skateboard Control Module Replacement, Control Module: passo 3, immagine 3 di 3
    • Flip the skateboard back over.
    • Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
    • While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
    • Separate the trucks and control module from the board.
  4. RazorX DLX Electric Skateboard Control Module Replacement: passo 4, immagine 1 di 3 RazorX DLX Electric Skateboard Control Module Replacement: passo 4, immagine 2 di 3 RazorX DLX Electric Skateboard Control Module Replacement: passo 4, immagine 3 di 3
    • Remove the four 20 mm bolts using a 4 mm Allen key, then remove the metal plate to separate the motor from the trucks.
    • Separate the wheel motor from the trucks
  5. RazorX DLX Electric Skateboard Control Module Replacement: passo 5, immagine 1 di 1
    • Remove the two 15 mm Phillips #00 screws to free the motor cable.
    • Remove the two 15 mm Phillips #00 screws securing the battery cage.
    • You will still need to remove the standoffs to fully remove the battery cage.
  6. RazorX DLX Electric Skateboard Control Module Replacement: passo 6, immagine 1 di 3 RazorX DLX Electric Skateboard Control Module Replacement: passo 6, immagine 2 di 3 RazorX DLX Electric Skateboard Control Module Replacement: passo 6, immagine 3 di 3
    • Remove the two standoffs holding the battery cage in place with an 8 mm wrench.
    • The standoffs have a nylon washer on either side of the battery cage.
    • Lift the battery cage up and out of the control module.
  7. RazorX DLX Electric Skateboard Control Module Replacement: passo 7, immagine 1 di 3 RazorX DLX Electric Skateboard Control Module Replacement: passo 7, immagine 2 di 3 RazorX DLX Electric Skateboard Control Module Replacement: passo 7, immagine 3 di 3
    • Remove the 20 mm Phillips #0 screw.
    • Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
    • Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
    • Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
    • A hall effect sensor is used to tell the board where the motor is in its rotation.
    • You will need to remove silicone and hot glue to remove the connectors.
  8. RazorX DLX Electric Skateboard Control Module Replacement: passo 8, immagine 1 di 2 RazorX DLX Electric Skateboard Control Module Replacement: passo 8, immagine 2 di 2
    • Disconnect the three green butt connectors.
    • These connectors will require a decent amount of force to pull them apart.
  9. RazorX DLX Electric Skateboard Control Module Replacement: passo 9, immagine 1 di 1
    • Remove the Control Module by lifting it out of the plastic housing.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Cuesta, Team 20-4, Krynen Fall 2024 Membro di Cuesta, Team 20-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G4
5 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 169
