Salta al contenuto principale
Razer Naga Epic Chroma Battery Replacement
Cosa ti serve
  1. Razer Naga Epic Chroma Battery Replacement, Razer Naga Epic Chroma Disassembly: passo 1, immagine 1 di 1
    • Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
  2. Razer Naga Epic Chroma Battery Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the four screws.
  3. Razer Naga Epic Chroma Battery Replacement: passo 3, immagine 1 di 1
    • Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
    • When removing the chassis, carefully unplug the cord connecting to the top mouse buttons.
  4. Razer Naga Epic Chroma Battery Replacement: passo 4, immagine 1 di 1
    • Gently pull up on the right plate on the mouse; separating it.
    • Carefully repeat this step for the left side.
    • Be wary of the cable connecting to the twelve mouse buttons located on the left plate. This can be disconnected if needed.
  5. Razer Naga Epic Chroma Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Take your nylon spudger to gently pry the battery pack from the device.
    • Remove the foam on the battery shell for your new battery.
  6. Razer Naga Epic Chroma Battery Replacement: passo 6, immagine 1 di 1
    • Unplug the power cord from the circuit board in the mouse.
  7. Razer Naga Epic Chroma Battery Replacement: passo 7, immagine 1 di 1
    • Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
    • Insert the new battery into the battery socket.
    • Place the foam on the surface of the new battery (reference Step 5).
Conclusione
Altre 7 persone hanno completato questa guida.
13 Commenti
Do you have battery for sell?
BcTwenty9 - Replica
You can purchase the battery from Amazon. I used the recommendation from ak48disk below, switching the battery leads: https://www.amazon.com/gp/product/B0767K...
Dan Mergens -
Anyone know where to buy a new battery?
Antony Lynch - Replica
Showing how to remove the old battery but not showing or writing what kind of battery one must have (type, where to buy, …) to replace the old one is somewhat stupid - really stupid!
Gooly - Replica
that battery appears to be very swollen………
Levi Coffey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 100
Tutti i Tempi: 14,429
