Salta al contenuto principale
Razer Kishi Direction Pad Replacement
Cosa ti serve
  1. Razer Kishi Direction Pad Replacement, Remove the screws: passo 1, immagine 1 di 1
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
  2. Razer Kishi Direction Pad Replacement, Release the bottom edge clips: passo 2, immagine 1 di 3 Razer Kishi Direction Pad Replacement, Release the bottom edge clips: passo 2, immagine 2 di 3 Razer Kishi Direction Pad Replacement, Release the bottom edge clips: passo 2, immagine 3 di 3
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
  3. Razer Kishi Direction Pad Replacement, Release the side edge clips: passo 3, immagine 1 di 2 Razer Kishi Direction Pad Replacement, Release the side edge clips: passo 3, immagine 2 di 2
    • Slide the opening pick along the right edge to loosen the plastic clips.
  4. Razer Kishi Direction Pad Replacement, Release the top edge clips: passo 4, immagine 1 di 2 Razer Kishi Direction Pad Replacement, Release the top edge clips: passo 4, immagine 2 di 2
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
  5. Razer Kishi Direction Pad Replacement: passo 5, immagine 1 di 3 Razer Kishi Direction Pad Replacement: passo 5, immagine 2 di 3 Razer Kishi Direction Pad Replacement: passo 5, immagine 3 di 3
    • Carefully lift the top side and unfold it to the right, like a book.
  6. Razer Kishi Direction Pad Replacement, Disconnect the interconnect cable: passo 6, immagine 1 di 3 Razer Kishi Direction Pad Replacement, Disconnect the interconnect cable: passo 6, immagine 2 di 3 Razer Kishi Direction Pad Replacement, Disconnect the interconnect cable: passo 6, immagine 3 di 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
  7. Razer Kishi Direction Pad Replacement, Remove the screws: passo 7, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
  8. Razer Kishi Direction Pad Replacement, Remove the breakout board: passo 8, immagine 1 di 3 Razer Kishi Direction Pad Replacement, Remove the breakout board: passo 8, immagine 2 di 3 Razer Kishi Direction Pad Replacement, Remove the breakout board: passo 8, immagine 3 di 3
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
  9. Razer Kishi Direction Pad Replacement, Remove the screws: passo 9, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
  10. Razer Kishi Direction Pad Replacement, Remove the trigger: passo 10, immagine 1 di 2 Razer Kishi Direction Pad Replacement, Remove the trigger: passo 10, immagine 2 di 2
    • Remove the shoulder trigger.
  11. Razer Kishi Direction Pad Replacement, Lift the shoulder button board: passo 11, immagine 1 di 2 Razer Kishi Direction Pad Replacement, Lift the shoulder button board: passo 11, immagine 2 di 2
    • Use a pair of blunt nose tweezers to lift out the shoulder button board.
  12. Razer Kishi Direction Pad Replacement, Remove the screws: passo 12, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the two 5.9 mm-long screws.
  13. Razer Kishi Direction Pad Replacement, Remove the board: passo 13, immagine 1 di 2 Razer Kishi Direction Pad Replacement, Remove the board: passo 13, immagine 2 di 2
    • Pull the mainboard straight out of the frame to remove it.
  14. Razer Kishi Direction Pad Replacement, Remove the rubber cover: passo 14, immagine 1 di 3 Razer Kishi Direction Pad Replacement, Remove the rubber cover: passo 14, immagine 2 di 3 Razer Kishi Direction Pad Replacement, Remove the rubber cover: passo 14, immagine 3 di 3
    • Remove the rubber cover that is attached on top of the direction pad.
  15. Razer Kishi Direction Pad Replacement, Remove the direction pad: passo 15, immagine 1 di 3 Razer Kishi Direction Pad Replacement, Remove the direction pad: passo 15, immagine 2 di 3 Razer Kishi Direction Pad Replacement, Remove the direction pad: passo 15, immagine 3 di 3
    • Remove the direction pad.
Conclusione
Adriana Zwink
Membro da: 12/18/19
48.500 Reputazione
167 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.198 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,411
