Salta al contenuto principale
Razer Blade RZ09-0130 2015 Battery Replacement
Cosa ti serve
  1. Razer Blade RZ09-0130 2015 Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Razer Blade RZ09-0130 2015 Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the device before beginning.
    • Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
  2. Razer Blade RZ09-0130 2015 Battery Replacement: passo 2, immagine 1 di 2 Razer Blade RZ09-0130 2015 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the back panel from the laptop by sliding it away from the hinge.
    • This device is missing the battery. Make sure to detach the battery connector before proceeding with laptop repairs.
  3. Razer Blade RZ09-0130 2015 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Detach the battery's ribbon cable from the motherboard.
  4. Razer Blade RZ09-0130 2015 Battery Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the six 3 mm screws securing the battery.
    • Lift the battery up and out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,002
