Salta al contenuto principale
Razer Barracuda X Battery Replacement
Cosa ti serve
  1. Razer Barracuda X Battery Replacement, Battery: passo 1, immagine 1 di 3 Razer Barracuda X Battery Replacement, Battery: passo 1, immagine 2 di 3 Razer Barracuda X Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the cushion by pulling it off from the edge and out from the grooves.
    • Continue to pull the cushion away from the speaker until the cushion is fully separated.
  2. Razer Barracuda X Battery Replacement: passo 2, immagine 1 di 1
    • Remove the four 6 mm Phillips #1 screws from the left side of the speaker casing.
  3. Razer Barracuda X Battery Replacement: passo 3, immagine 1 di 2 Razer Barracuda X Battery Replacement: passo 3, immagine 2 di 2
    • Gently pull the speaker casing away from the shell.
    • Place it face down to access the battery.
  4. Razer Barracuda X Battery Replacement: passo 4, immagine 1 di 2 Razer Barracuda X Battery Replacement: passo 4, immagine 2 di 2
    • Unplug the battery from the socket.
    • Use a spudger to gently lift the battery up.
    • Remove the battery.
Conclusione
Altre 3 persone hanno completato questa guida.
Micah Ortiz
Membro da: 10/26/22
247 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 2-3, Petersen Fall 2022 Membro di UMass Dartmouth, Team 2-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G3
4 Membri
7 Guide realizzate
7 Commenti
What is the voltage of the battery?
Bavo Van Rillaer - Replica
It’s a 3.7V battery.
Dániel Baranyi -
Battery info Barracuda X Wireless (2022) version but I believe the non 2022 version also:
55345PN2 / 1ICP6/35/51 1200mAh/4.44Wh
Dominick -
Si, 3,7 v se ve muy mal en la foto del Paso 4
Carlos López (España - Spain) - Replica
How small is that battery?? i took mine apart and i saw i got the wrong size battery in general.
JPStruggle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 51
Ultimi 30 Giorni: 208
Tutti i Tempi: 3,341
