Salta al contenuto principale
RYOBI P422 Safety Trigger Spring Replacement
Cosa ti serve
    1. RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: passo 1, immagine 1 di 2 RYOBI P422 Safety Trigger Spring Replacement, Battery and Handle: passo 1, immagine 2 di 2
      • To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
      • To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
      Chiedi a FixBot
      Aggiungi Commento
    1. RYOBI P422 Safety Trigger Spring Replacement, Safety Trigger Spring: passo 2, immagine 1 di 1
      • Lay grinder flat on its side so the screws are facing up
      Chiedi a FixBot
      Aggiungi Commento
    2. RYOBI P422 Safety Trigger Spring Replacement: passo 3, immagine 1 di 3 RYOBI P422 Safety Trigger Spring Replacement: passo 3, immagine 2 di 3 RYOBI P422 Safety Trigger Spring Replacement: passo 3, immagine 3 di 3
      • Remove the four 1.8 cm screws from the lower and midsection of the body with a T20-20 Torque screwdriver.
      • Remove the 3.7 cm screws from the upper section of the body, with the same screwdriver
      Chiedi a FixBot
      Aggiungi Commento
    3. RYOBI P422 Safety Trigger Spring Replacement: passo 4, immagine 1 di 3 RYOBI P422 Safety Trigger Spring Replacement: passo 4, immagine 2 di 3 RYOBI P422 Safety Trigger Spring Replacement: passo 4, immagine 3 di 3
      • Now that the two halves are unscrewed, remove the top half
      Chiedi a FixBot
      Aggiungi Commento
    4. RYOBI P422 Safety Trigger Spring Replacement: passo 5, immagine 1 di 3 RYOBI P422 Safety Trigger Spring Replacement: passo 5, immagine 2 di 3 RYOBI P422 Safety Trigger Spring Replacement: passo 5, immagine 3 di 3
      • Remove the safety trigger along with the spring.
      • To remove the spring, pull it gently off the bottom of the trigger.
      • When putting a new spring in make sure it slides into the grove on the bottom of the trigger.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 36
Tutti i Tempi: 1,988
