Salta al contenuto principale
RCA CC310 Viewfinder Replacement
Cosa ti serve
    1. RCA CC310 Viewfinder Replacement, Viewfinder: passo 1, immagine 1 di 2 RCA CC310 Viewfinder Replacement, Viewfinder: passo 1, immagine 2 di 2
      • Slide a spudger between the plastic rail and the metal tab on the left side of the rail. Push away from the camcorder to release the flap.
      • Pushing the viewfinder assembly to the right makes lifting the flap easier.
      • Slide the lifted flap towards the viewfinder assembly until the viewfinder is free from the rail.
      Chiedi a FixBot
      Aggiungi Commento
    2. RCA CC310 Viewfinder Replacement: passo 2, immagine 1 di 3 RCA CC310 Viewfinder Replacement: passo 2, immagine 2 di 3 RCA CC310 Viewfinder Replacement: passo 2, immagine 3 di 3
      • Unscrew the 7mm ph#0 screw on the underside where the cable connects.
      • Lift the plastic where the cable connects off of the viewfinder assembly.
      • Disconnect the cable inside by pulling it apart.
      Chiedi a FixBot
      Aggiungi Commento
    3. RCA CC310 Viewfinder Replacement: passo 3, immagine 1 di 2 RCA CC310 Viewfinder Replacement: passo 3, immagine 2 di 2
      • Unscrew two 7.0mm ph#0 screws on the underside of the viewfinder assembly.
      • Lift the viewfinder plastic assembly up and remove.
      Chiedi a FixBot
      Aggiungi Commento
    4. RCA CC310 Viewfinder Replacement: passo 4, immagine 1 di 1
      • Flip back the viewfinder access tab.
      • Unscrew the 7.0mm ph #0 screw next to the mirror.
      Chiedi a FixBot
      Aggiungi Commento
    5. RCA CC310 Viewfinder Replacement: passo 5, immagine 1 di 3 RCA CC310 Viewfinder Replacement: passo 5, immagine 2 di 3 RCA CC310 Viewfinder Replacement: passo 5, immagine 3 di 3
      • Lift off both sides of the plastic assembly.
      • When reassembling, if the housing doesn't connect properly, try turning the focus wheel.
      Chiedi a FixBot
      Aggiungi Commento
    6. RCA CC310 Viewfinder Replacement: passo 6, immagine 1 di 2 RCA CC310 Viewfinder Replacement: passo 6, immagine 2 di 2
      • Lift the microphone circuit board straight up.
      • Unclip the cable connected to the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    7. RCA CC310 Viewfinder Replacement: passo 7, immagine 1 di 3 RCA CC310 Viewfinder Replacement: passo 7, immagine 2 di 3 RCA CC310 Viewfinder Replacement: passo 7, immagine 3 di 3
      • Lift plastic housing and guide the wires from underneath.
      • Lift out the entire circuit board and viewfinder.
      • Replace entire circuit board and viewfinder assembly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 5-20, Amido Winter 2011 Membro di Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Membri
14 guide realizzate
1Commento della guida
do you know where i can find a relacement one of these parts
Connor Byrley - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 43
Tutti i Tempi: 2,944
