Salta al contenuto principale
Quick Antenna Connection Check for Delphi MyFi XM2GO
Cosa ti serve
  1. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: passo 1, immagine 1 di 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: passo 1, immagine 2 di 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery Cover: passo 1, immagine 3 di 3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
    Chiedi a FixBot
    Aggiungi Commento
  2. Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: passo 2, immagine 1 di 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: passo 2, immagine 2 di 3 Quick Antenna Connection Check for Delphi MyFi XM2GO, Battery: passo 2, immagine 3 di 3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
    Chiedi a FixBot
    Aggiungi Commento
  3. Quick Antenna Connection Check for Delphi MyFi XM2GO, Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 3, immagine 1 di 1
    • Under the battery is a magnetic mat, shown in red, that shields battery interference with the reception of the XM Satellite antenna.
    • This mat is stuck to the back of the device like a sticker and can be removed.
    • CAUTION: Do not operate the device without this magnetic shield.
    Chiedi a FixBot
    Aggiungi Commento
  4. Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 4, immagine 1 di 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 4, immagine 2 di 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 4, immagine 3 di 3
    • On the bottom left side of the magnetic mat, the corner can be lifted up to reveal the U.FL antenna connector. A spudger or your fingernails can be used to pry up the corners.
    • These U.FL antenna connections are standard for most portable devices and WiFi cards. They may become detached through use and may be checked if no reception is present.
    • Lift up the corner and notice the two connectors going to the PCB.
    Chiedi a FixBot
    Aggiungi Commento
  5. Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 5, immagine 1 di 2 Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 5, immagine 2 di 2
    • Both of these connectors must be firmly attached to the PCB. Try pressing them firmly to make sure they are making full contact.
    Chiedi a FixBot
    Aggiungi Commento
  6. Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 6, immagine 1 di 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 6, immagine 2 di 3 Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 6, immagine 3 di 3
    • On the top right corner, the magnetic mat can be lifted up to check another U.FL connector as with the 3rd step.
    • This mat can be pressed down again to secure after checking the connector.
    Chiedi a FixBot
    Aggiungi Commento
  7. Quick Antenna Connection Check for Delphi MyFi XM2GO: passo 7, immagine 1 di 1
    • Try pressing down on the U.FL connector, as seen in this picture, to ensure a secure connection.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Clemson, Team 1-2, Benson Spring 2012 Membro di Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Membri
9 guide realizzate
1Commento della guida
la radio sigue sin funcionar
luis - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 9
Ultimi 30 giorni: 35
Tutti i Tempi: 3,438
