Salta al contenuto principale
ProntoTec Axius Screen Replacement
Cosa ti serve
  1. ProntoTec Axius Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
    • Place the tablet face-up on a flat table
    Chiedi a FixBot
    Aggiungi Commento
  2. ProntoTec Axius Screen Replacement: passo 2, immagine 1 di 1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
    Chiedi a FixBot
    Aggiungi Commento
  3. ProntoTec Axius Screen Replacement: passo 3, immagine 1 di 1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
    Chiedi a FixBot
    Aggiungi Commento
  4. ProntoTec Axius Screen Replacement: passo 4, immagine 1 di 1
    • Remove all of the yellow tape that is on the device with the spudger.
    • Be careful not to cut any wires that are under the tapes.
    Chiedi a FixBot
    Aggiungi Commento
  5. ProntoTec Axius Screen Replacement: passo 5, immagine 1 di 2 ProntoTec Axius Screen Replacement: passo 5, immagine 2 di 2
    • Use the flat end of the spudger to gently pry the battery from the back of the screen.
    Chiedi a FixBot
    Aggiungi Commento
  6. ProntoTec Axius Screen Replacement: passo 6, immagine 1 di 2 ProntoTec Axius Screen Replacement: passo 6, immagine 2 di 2
    • Use a spudger to lift all the ribbon cable clamps
    • Detach all three ribbon cables from the clamps
    Chiedi a FixBot
    Aggiungi Commento
  7. ProntoTec Axius Screen Replacement: passo 7, immagine 1 di 3 ProntoTec Axius Screen Replacement: passo 7, immagine 2 di 3 ProntoTec Axius Screen Replacement: passo 7, immagine 3 di 3
    • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
    Chiedi a FixBot
    Aggiungi Commento
  8. ProntoTec Axius Screen Replacement: passo 8, immagine 1 di 3 ProntoTec Axius Screen Replacement: passo 8, immagine 2 di 3 ProntoTec Axius Screen Replacement: passo 8, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Heavy-Duty Spudger
    • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
    • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
    Chiedi a FixBot
    Aggiungi Commento
  9. ProntoTec Axius Screen Replacement: passo 9, immagine 1 di 1
    • Remove the orange tab from the back of the screen as shown in the picture
    Chiedi a FixBot
    Aggiungi Commento
  10. ProntoTec Axius Screen Replacement: passo 10, immagine 1 di 2 ProntoTec Axius Screen Replacement: passo 10, immagine 2 di 2
    • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
UMass Dartmouth, Team 5-3, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 Membri
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 26
Tutti i Tempi: 582
