Salta al contenuto principale
Programming the Smart Key
  1. Programming the Smart Key, Enter Settings: passo 1, immagine 1 di 1
    • With the Clix on and past the start-up screen, go down to settings.
    • Select it by pressing right.
    Chiedi a FixBot
    Aggiungi Commento
  2. Programming the Smart Key, Enter Smart Key: passo 2, immagine 1 di 1
    • In settings, go down and press right to select 'Smart Key'.
    Chiedi a FixBot
    Aggiungi Commento
  3. Programming the Smart Key, Select an operation: passo 3, immagine 1 di 1
    • select the function of your choice by pressing right on anything in the Smart key options menu.
    • The next steps are rundowns of all the operations of the Smart Key.
    Chiedi a FixBot
    Aggiungi Commento
  4. Programming the Smart Key, OP-1: Home: passo 4, immagine 1 di 1
    • Will send the user straight to the Clix home screen when pressed.
    Chiedi a FixBot
    Aggiungi Commento
  5. Programming the Smart Key, OP-2: Play/Pause: passo 5, immagine 1 di 1
    • As it says, plays or pauses any music or audio that is playing.
    Chiedi a FixBot
    Aggiungi Commento
  6. Programming the Smart Key, OP-3: Shuffle all: passo 6, immagine 1 di 1
    • Plays and shuffles all music and audio books when pressed.
    • Note the symbol in the top right of the screen that indicates that it's in shuffle mode.
    Chiedi a FixBot
    Aggiungi Commento
  7. Programming the Smart Key, OP-4: Display Orientation: passo 7, immagine 1 di 1
    • Rotates the display from landscape to portrait mode, and vice versa when pressed.
    Chiedi a FixBot
    Aggiungi Commento
  8. Programming the Smart Key, OP-5: Start/Stop Recording: passo 8, immagine 1 di 1
    • Takes the user to the recorder program and automatically starts recording voice.
    Chiedi a FixBot
    Aggiungi Commento
  9. Programming the Smart Key, OP-6: Add to Quick List: passo 9, immagine 1 di 1
    • when pressed, the Smart Key adds whatever you may be listening to into the Quick List playlist on the Clix.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Now that you know what to do with the Smart Key, you can enjoy the convenience of your selected feature!
Rando_GUY
Membro da: 05/17/23
893 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 18
Tutti i Tempi: 326
