Salta al contenuto principale
ProScan PLT7223G Screen Replacement
Cosa ti serve
    1. ProScan PLT7223G Screen Replacement, Screen: passo 1, immagine 1 di 1
      • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
      Chiedi a FixBot
      Aggiungi Commento
    2. ProScan PLT7223G Screen Replacement: passo 2, immagine 1 di 1
      • Use the blue plastic opening tool to pry open the tablet.
      • You will hear popping sounds. That's okay.
      • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    3. ProScan PLT7223G Screen Replacement: passo 3, immagine 1 di 1
      • Remove three 4 mm screws from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    4. ProScan PLT7223G Screen Replacement: passo 4, immagine 1 di 1
      • Insert a spudger under the black tape that connects the silver wire to the interior of the front panel
      • Pull back the black tape with the spudger until it can be lifted up with your fingers.
      • Use your fingers to grab and lift the remainder of the black tape from device panel.
      Chiedi a FixBot
      Aggiungi Commento
    5. ProScan PLT7223G Screen Replacement: passo 5, immagine 1 di 1
      • Use a plastic opening tool to push back the ZIF connector to release the ribbon wire on the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    6. ProScan PLT7223G Screen Replacement: passo 6, immagine 1 di 1
      • Insert an opening tool underneath the silver base of the internal device element.
      • Use the opening tool to pry the element out of the case that holds the screen.
      • You will need to release a number of clips in order to remove the screen.
      • Be careful not to damage the motherboard or battery as you go.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 27
Tutti i Tempi: 2,101
