Salta al contenuto principale
ProScan PLT7050 Screen Replacement
Cosa ti serve
    1. ProScan PLT7050 Screen Replacement, Open Device: passo 1, immagine 1 di 1
      • Make sure device is unplugged and turned off while working on the device.
      • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. ProScan PLT7050 Screen Replacement: passo 2, immagine 1 di 1
      • Use the plastic opening tools to pry the back of the tablet open.
      • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
      • May be helpful if you start by the microSD slot.
      Chiedi a FixBot
      Aggiungi Commento
    1. ProScan PLT7050 Screen Replacement, Motherboard: passo 3, immagine 1 di 2 ProScan PLT7050 Screen Replacement, Motherboard: passo 3, immagine 2 di 2
      • Remove the 3 black pieces of tape from the device.
      • Remove the 5 yellow pieces of tape from the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. ProScan PLT7050 Screen Replacement: passo 4, immagine 1 di 2 ProScan PLT7050 Screen Replacement: passo 4, immagine 2 di 2
      • Use the soldering tool to remove the 3 wires from the mother board to the battery (black, red, gray).
      • Soldering tool will get hot.
      Chiedi a FixBot
      Aggiungi Commento
    3. ProScan PLT7050 Screen Replacement: passo 5, immagine 1 di 2 ProScan PLT7050 Screen Replacement: passo 5, immagine 2 di 2
      • Remove the speaker wires from the motherboard with the soldering tool.
      Chiedi a FixBot
      Aggiungi Commento
    4. ProScan PLT7050 Screen Replacement: passo 6, immagine 1 di 1
      • Remove 3 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    5. ProScan PLT7050 Screen Replacement: passo 7, immagine 1 di 3 ProScan PLT7050 Screen Replacement: passo 7, immagine 2 di 3 ProScan PLT7050 Screen Replacement: passo 7, immagine 3 di 3
      • Use the plastic opening tool to pop open all 3 ZIF connector tabs connected to the motherboard.
      • Remove each ribbon from the ZIF connector port.
      Chiedi a FixBot
      Aggiungi Commento
    6. ProScan PLT7050 Screen Replacement: passo 8, immagine 1 di 1
      • Lift the motherboard off the device taking care to pull the ports out of the casing.
      Chiedi a FixBot
      Aggiungi Commento
    1. ProScan PLT7050 Screen Replacement, Screen: passo 9, immagine 1 di 3 ProScan PLT7050 Screen Replacement, Screen: passo 9, immagine 2 di 3 ProScan PLT7050 Screen Replacement, Screen: passo 9, immagine 3 di 3
      • You will need two plastic opening tools.
      • Use one of the plastic opening tools next to one of the black clips on the side of silver screen.
      • Use the second plastic opening tool to push back the black clip next to the one you have worked on. Push the second plastic opening tool under the screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. ProScan PLT7050 Screen Replacement: passo 10, immagine 1 di 1
      • Wiggle the screen and pull it from the casing.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 25
Tutti i Tempi: 559
