Salta al contenuto principale
PowerA Fusion Controller For Xbox One Motherboard Replacement
Cosa ti serve
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: passo 1, immagine 1 di 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: passo 1, immagine 2 di 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: passo 1, immagine 3 di 3
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 2, immagine 1 di 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 3, immagine 1 di 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 3, immagine 2 di 2
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: passo 4, immagine 1 di 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: passo 4, immagine 2 di 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: passo 4, immagine 3 di 3
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 5, immagine 1 di 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
Conclusione
Andrea
Membro da: 09/26/17
623 Reputazione
4 Guide realizzate
USF Tampa, Team S14-G4, Boczar Fall 2017 Membro di USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Membri
5 Guide realizzate
Un commento
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,935
