Salta al contenuto principale
Polycom SoundStation Internal Keyboard Replacement
Cosa ti serve
  1. Polycom SoundStation Internal Keyboard Replacement, Back Housing: passo 1, immagine 1 di 1
    • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
    • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
    Chiedi a FixBot
    Aggiungi Commento
  2. Polycom SoundStation Internal Keyboard Replacement: passo 2, immagine 1 di 2 Polycom SoundStation Internal Keyboard Replacement: passo 2, immagine 2 di 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
    Chiedi a FixBot
    Aggiungi Commento
  3. Polycom SoundStation Internal Keyboard Replacement, Internal Keyboard: passo 3, immagine 1 di 2 Polycom SoundStation Internal Keyboard Replacement, Internal Keyboard: passo 3, immagine 2 di 2
    • Gently lift the internal keyboard off of the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 21
Tutti i Tempi: 1,693
