Introduzione
The Polaroid LCD-0700P is a car DVD player used to display movies while on the go. This guide is to show how to replace the front panel buttons on the DVD player. It would be referenced when the buttons on the DVD player are not working properly and don't do what they are designed to do. You would follow these instructions after checking that the buttons are aligned, if they are not simply jiggle them back into place. There are no special skills required but be careful of sharp edges and connecting wires. Make sure to power off and disconnect device from any external power source before beginning this process.
Cosa ti serve
Turn the entire device over, so that the underside of the device is facing upward.
With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
Separate the halves of the case.
Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
Use two blue plastic opening tools to remove the three wire connectors on the side of the input/output board.
Use a Philips #0 screwdriver to remove the five screws on the board.
Lift board from case.
Remove the five different connections to this board. Two from the speakers, two from input/output board and the orange ribbon cable.
Remove connections from input/output board and speaker with the plastic opening tool.
Remove the orange ribbon cable using the plastic opening tool to release the two brown retention tabs.
To reassemble your device, follow these instructions in reverse order using the electrical tape to replace the ones you removed.
